2nd Jun 2018, 9:19 pm | #1 |
Dial lubrication
I have a dial telephone which was installed about 50 years ago. I fitted a master socket and not long ago asked BT to lubricate the dial which gradually had got stiffer. I told them that I would no longer pay (I think I had paid about £500 over the yearts) and a man came and replaced my master socket. He would not touch the phone. I persuaded him to leave the old hard wired phone for the bell and power loss emergencies.
How do I remove the dial and strip it to get it working again? |
2nd Jun 2018, 10:51 pm | #2 |
Re: Dial lubrication
The GPO document for the Dial No 10 used on Bakelite phones is at http://www.britishtelephones.com/tel%20auto%20b5126.htm whilst that on the later plastic 700 series phones which started to be fitted at an extra cost (regardless of colour - you paid extra for a 'modern' phone until the late 1960's) is at http://www.britishtelephones.com/dial21.htm
I'd avoid lubricating it - I tend to find that the governor gets dirty and cleaning inside the inside of the governor (where the ends of the arms rub when they go at speed) and the weighs on the ends of the arms. That is as far as I usually go. If oiled, it tends to dry up clogging things up. What type of phone is it? The three digit model number should be on the bottom of the phone. Ian CNet 0352 2345 GW4BTW |
2nd Jun 2018, 11:45 pm | #3 |
Thanks Ian,
The phone is fixed to the wall. I managed to get the cream plastic cover off by removing a screw adjacent to the cable entry. I could not get the phone off the wall, there seems to be two hooks at the top and some fixture at the bottom which I cannot see. Does it just need a bigger hammer to thump it uphill? Inside is a label T.U. D92732 TMA/2 I eventually managed to put the top back on and the dial now works with a bit of encouragement. This may be due to the hot weather thinning the lubricant. I dialled 1471 OK but there is some crackly noise. This noise is not evident on my cordless phones. I may leave it as it is. |
3rd Jun 2018, 6:06 am | #4 |
sounds like a Tele 711 wallphone, the crackling could be from the carbon granule microphone
"Oh yes I love television, all those wiggly lines"! |
4th Jun 2018, 8:19 am | #5 |
Whatever you do, do not lubricate with anything containing silicone!
dsk |
5th Jun 2018, 1:52 am | #6 | |
The crackling will either be the carbon mic, dial contacts or hook switch, possibly a bit of all three. Michael. |
