23rd Apr 2018, 12:11 pm | #1 |
19in tuner I.D
I've just acquired a broadcast receiver unit, it's in a 19in chassis format. There's no maker's name or plate on it anywhere. It's built to near-military standard with chassis isolated from the front panel on shock mounts and the tuning capacitor mounted on its own shock mountings. I would think it's early post-war.
I suspect it's from an RGD radiogram, there's no HT rail, which is supplied through a Jones plug on the side. It came with a BSR record deck with a plug that fits it. Does anyone know the model?
Kevin |
23rd Apr 2018, 12:23 pm | #2 |
Re: 10in tuner I.D
Looks very similar to the unit fitted to the 1046C
http://www.rgd.org.uk/rgd_exh_pg_1046C.htm Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 23rd Apr 2018 at 12:27 pm. Reason: Typo G instead of C |
23rd Apr 2018, 1:20 pm | #3 |
Re: 10in tuner I.D
That looks like a direct hit!
147 gns in 1946 is around a quarter of the price of a house. It looks rather well made. I suspect it may also have been used in a different console including a gram turntable. David
23rd Apr 2018, 1:53 pm | #4 |
Re: 10in tuner I.D
Hello,
Possibly even more similar to the 1046G:- http://www.rgd.org.uk/rgd_exh_pg_1046G.htm Yours, Richard Last edited by Mr Moose; 23rd Apr 2018 at 2:01 pm. |
23rd Apr 2018, 2:38 pm | #5 |
Re: 10in tuner I.D
If I've done my sums right, in 2018 money that receiver would cost around £50000! (based on David's comment that 147 guineas (£154.35) was about a quarter of the price of a house in 1946) It should have been very well built for that kind of money!!
Even based on wage inflation in 70 years, that £154.35 works out at around £15,000 in 2018 money! |
23rd Apr 2018, 3:00 pm | #6 |
Re: 10in tuner I.D
Houses have gone up faster than other things, though .....
Montoya Mansions cost me just shy of £30 000 in 1996. When I paid off the mortgage in 2011, the place was worth four times that; during which time, my wages after tax had barely doubled. And even if I did sell, I'd only be able to afford another two-up, two-down terraced house .....
23rd Apr 2018, 5:31 pm | #7 |
Re: 10in tuner I.D
Thanks! 1036C looks about right. The other one would mean the stations were written on their sides.
TBH before I thought of RGD I thought first of all it was part of a PA system (but why the wood!) and then part of a yacht (the shockmount) then realised it must've been a high end consumer product. I'd love to know what happened to that riot of walnut though. Edit: 147gns on the This Is Money website translates as £6300 in today's money. They use historic inflation records to calculate it.
Kevin |
23rd Apr 2018, 6:05 pm | #8 |
Re: 10in tuner I.D
I take it 1036C is a typo
Unfortunately the rest of it including the amplifier and power unit has been spirited away to feed the Valve Audio craze, frustrating but there it is. There are arguments from both sides I think its a shame it isn't what it was, but thats me. Cheers Mike T
23rd Apr 2018, 7:05 pm | #9 |
Re: 10in tuner I.D
The rear view of the chassis shows a circular two pin socket which has two slots, to take a two blade plug, one blade somewhat wider than the other.
That type of connector was commonly used for loudspeaker connections on mid 1940's onward, Bell & Howell 16mm sound projectors. I have dismatled a number of these and still have such plugs and sockets. It seems strange to use one on a radiogram. |
23rd Apr 2018, 7:16 pm | #10 |
Re: 10in tuner I.D
the plug I think is for the gram motor which is switched on when you turn the left knob up to illuminate 'G'. The mains cable and plug came with it. The 4-pin socket above that matches the one on the deck that is also here with me.
Sorry yes, a couple of typos, the model and also the title should read '19in' tuner. Must be the stress of doing it at work!!
Kevin |
23rd Apr 2018, 7:26 pm | #11 | |
Re: 10in tuner I.D
I have all kinds of test equipment from the 50's and 60's that use these as interlock plugs, selector plugs and even LT supply plugs Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 23rd Apr 2018 at 7:51 pm. |
24th Apr 2018, 9:22 am | #12 |
Re: 19in tuner I.D
Interesting about the plugs supplying gram motor!
I hope you never let a Bell and Howell loudspeaker owner anywhere near it!! |
