27th Apr 2020, 11:07 am | #1 |
WS-19 transformer?
Looking in my stash for an earpiece the other day I found an assembly I put together as a teen - an earpiece sunk into the end of a Hunts electrolytic case. Much to my surprise, there was also inside the little transformer shown. My suspicion is that I re-purposed a transformer from a stripped-out B-set from a 19 set but I have no recollection of using it. I do recall removing a B-set from a Mk II 19 set (like most other owners).
The wires are 2x black, 1x red, 1x beige, 1x cream. They may have contrasting additional colours in the insulation but the wax/varnish makes this unclear. black to black: 6 Ohms red to beige: 6.7 kOhms cream: n/c 3.5cm wide, 3cm tall. Any ID comments, please? Graham
Half my stuff is junk - trouble is, I don't know which half! Last edited by llama; 27th Apr 2020 at 11:08 am. Reason: size matters |
27th Apr 2020, 1:34 pm | #2 |
Re: WS-19 transformer?
Try T4A or T4B, colours are probably altered by the protective spay.
The "no connection" is a screen. Orakle42 |
27th Apr 2020, 6:16 pm | #3 |
Thanks for that. Yes, seems very likely. Wireless for the Warrior shows both and I think the numbering scheme means they are the same spec but used in different positions. WftW doesn't give the spec for a T4x but the resistances given would tally with a mic transformer.
I seem to recall that this transformer is prone to either green spot or burnt out fine-wire-gauge secondary due to leaky capacitors. I may need it at some stage to fettle one of my Mk IIIs! Thanks again. Graham
Half my stuff is junk - trouble is, I don't know which half! |
