29th Apr 2019, 6:47 pm | #1 |
WS19 Mains Supply?
I am awaiting the delivery of what looks like a WS19 set power supply, now this is RCA and a mains one.
Question being was one ever made that was mains for the 19 set? or have I wasted some cash here? Thank you
29th Apr 2019, 7:18 pm | #2 |
Re: WS19 Mains Supply?
There's a third option (in the event there wasn't an original mains supply): is running it off mains of interest? If so, it might be a very good use of cash.
Graham
Half my stuff is junk - trouble is, I don't know which half! |
29th Apr 2019, 7:20 pm | #3 |
Wireless for the Warrior, Vol 2, WS19 (Cdn) p17 shows a mains unit. 110v.
Graham
29th Apr 2019, 8:54 pm | #4 |
There was probably a mains unit for base workshops use to allow service and repair.
Ed |
29th Apr 2019, 9:14 pm | #5 |
Thank you all, I will keep you posted when the power supply arrives. It was just over £30, which is not too bad but the postage was £17.50.
Hoping I have done right. Yes,I would like to run it off the mains, at present I have a home brew power supply.
29th Apr 2019, 10:38 pm | #6 |
For the second time this week I can't find an item I thought I'd come across David. My recollection was that I had recently seen a photograph of a WS19 Mains Unit [which I can't now locate] I had thought it would be in the thread started by trh01uk "Items for disposal which makes a generous pre-auction offer but apparently not
It would have tended to support Ed Dinning's very experienced comment! I wonder if I've seen what you've bought somewhere else David? I think the excellent photos that Richard has provided are an invaluable Forum resource, whether we are seeking to buy the individual items or not! Dave W Last edited by dave walsh; 29th Apr 2019 at 10:46 pm. |
29th Apr 2019, 11:26 pm | #7 |
Dave,
thanks for your encouraging comments about my photos. Interesting that you should see the photos as a forum resource - if such a group area were set up I would be happy to let photos be used to help keep a record of what equipment looks like. I don't have a mains WS19 psu - though I know an original one exists, as someone else has already mentioned. They are easy enough to make of course, the only difficulty is probably sourcing the 12-pin socket that's peculiar to the WS19 - though even that depends on how original one wants to be. Richard |
30th Apr 2019, 6:50 am | #8 |
Canada did make a mains supply into the early 1950s. I have and still use one for my 19 set. It was made by RCA Victor and dated 1950.
The power supply has a weak point in that the rectifiers can flash over and cause a winding to burn out. At that point it basically becomes a door stop as all windings, transformer and chokes, are encapsulated into one item. Best check for continuity on windings. Here's the schematic of the psu. |
30th Apr 2019, 8:20 am | #9 |
Thank you Bruce and all for getting this far. Hope that transformer is OK, if indeed this is the 19 set PSU.
Despite my many years of experience, I like many still need help from our excellent group.
30th Apr 2019, 9:22 am | #10 |
Nice example of how to draw a simple circuit for maximum confusion potential!
30th Apr 2019, 9:36 am | #11 |
A closer look at original listing shows 230/240AC possibly output and 12 volts input. Starting to think I might have slipped up buying it.
Oh well! We will see I guess, a little too much enthusiasm. Though, maybe I could get the modern mains PSU in the case.
30th Apr 2019, 12:20 pm | #12 |
I believe it is Canadian 19 set supply no 2. Though slightly got at, no voltage selector switch inside (12/24V Input) and a missing rectifier valve.
Wireless For The Warrior Compendium seems to confirm this. Time to find a circuit I think. Maybe just maybe not too bad a buy??
1st May 2019, 7:30 pm | #13 |
This is interesting, I distinctly remember having had an original supply suitable for UK mains, as well as one that used a vibrator or two and one with a dynamotor for battery use.
1st May 2019, 8:33 pm | #14 |
I remember:
1] A Canadian-Marconi-company 12V supply that had a vibrator for the receiver HT and a dynamotor for the TX - along with Russian labelling. 2] A British "Mk.3" PSU that had two dynamotors. I bought one of these from A.H.Thacker in Cheslyn Hay just before they closed. 3] Another PSU that was AC-only, 115-230V 50/60Hz. All these were 'official' military beasts. But then: 4] Various "Mains" supplies - advertised in 1950s/1960s PW, SWM etc, either a RX-only or RX-TX version. Some of these 'unofficial' ones were good, using oil-filled ex-Admiralty transformers etc; some of them were very bad (using over-run domestic-radio/radiogram-style mains transformers struggling to provide the LT to the full 19-set valve complement!) |
1st May 2019, 8:33 pm | #15 |
I must post pictures as I could be totally wrong yet.Mine has a vibrator and a transformer (not oil filled) rect valve missing and I think it might run on 12/24V DC in.
2nd May 2019, 6:23 am | #16 |
If it is the Canadian supply #2 it is 12/24 VDC in. It has a vibrator for receive & dynamotor for xmit. The rectifier is an 0Z4. There was an earlier supply that used 2 smaller dynamotors. The Canadian AC unit is known as "Supply Unit Rectifier #1" and was only 110 VAC in.
I've seen people re-use the cases for a homebrew AC supply. We wait the outcome. |
2nd May 2019, 9:07 am | #17 |
It is certainly or was 12/24V in. There is no sign whatever of a dynamotor motor though.The 12/24V switch has been removed.
