10th Jul 2008, 6:04 pm | #1 |
To strip or spray?
Hi all, i have just repaired my portadyne princess, now i have to start on the cabinet, the bakelite is in very good condition (underneath the terrible paintwork) So do i strip the paint & polish up the bakelite or respray it cream?
i think these were available unpainted with brown knobs & gold speaker mesh. If i respray it what should i use for primer? will car acrylic spray be ok? Btw picture of set looks better than it is Cheers Mark |
10th Jul 2008, 6:30 pm | #2 |
Re: To strip or spray?
Car acrylic has worked for me...it looks pink but I assume that is your camera? Either way you will need to strip it so why not make a decision then..Peter
10th Jul 2008, 6:40 pm | #3 |
Yes best strip if for a prof finish before spraying or you will wish you had done .Dont you need what they call an etching primer ? like on Aluminium to help it stick better
10th Jul 2008, 7:46 pm | #4 |
Hi Mark. I have one of these but I decided to strip it back to brown rather than re-spray.
The paint came off quite easily in warm, soapy water. I just need to find 3 brown knobs now! Cheers. SimonT.
The honesty of imperfection.......... |
10th Jul 2008, 8:19 pm | #5 |
You will need to strip the old paint off anyway.
Once it's off have a good look at the bakelite. Some manufacturers used different bakelite formulations for their painted sets for some reason, which don't look right unpainted. Sometimes you will find the bakelite is scratched, either to provide a key for the paint or because of accidental damage. If the bakelite looks right and is undamaged there's no reason why you shouldn't just polish it up rather than repainting. I've found car acrylic adheres to bakelite well without any fancy priming, but I'm a bit of a bodger It's stopping the stuff running that's difficult. Paul |
10th Jul 2008, 9:27 pm | #6 |
Thanks to all for your suggestions, I will try the hot soapy water method to remove the old paint, but you can bet i will be left with some stubborn bits
has anyone used nitromors on bakelite? if so does it affect the finish? as already said, all the old finish will have to be removed first.... then i will see how well it will polish up (out with rubbing compound & T-cut ) if it turns out well, will just re-spray knobs & grille. Mark |
11th Jul 2008, 7:46 am | #7 |
Mark
I'd be a bit wary of Nitromors or any sodium hydroxide based stripper - bakelite is porous and you might not get rid of all the stripper. Might be worth trying cellulose thinners on a small part?
Mike. |
11th Jul 2008, 8:03 am | #8 | |
http://www.thevalvepage.com/radios/u...1/ultrat40.htm It's white control knobs actually look rather nice against the dark bakelite ! If the speaker grill isn't rough, then wait to see what the set looks like - you may well find it looks nice too without having to respray it. TTFN, Jon |
11th Jul 2008, 9:17 am | #9 |
I had a Ferranti 546 which had lost most of its paint. When I removed the remainder of the paint prior to a respray, I was greeted by a beautiful gloss black cabinet. Even better than this, the knobs were a butterscotch catalin under the original paint. All of this, combined with the gold herringbone grill cloth, produced a simply stunning effect.
Admittedly the bakelite was not quite of the best standard (since it was intended to be painted) but I decided to leave it in its natural finish. Neil
11th Jul 2008, 10:14 am | #10 |
I use Nitromors to strip paint from bakelite when it won't come off with soap and water. It certainly doesn't do any major damage, but it's impossible to know what the bakelite would have looked like *without* the Nitromors.
If the paint won't come off you have little choice but use it. Paul |
11th Jul 2008, 10:35 am | #11 |
Is Nitromors caustic soda or methylene chloride based? Both are effective paint strippers but caustic is water based while methylene chloride is a solvent.
11th Jul 2008, 10:40 am | #12 | |
Paul |
11th Jul 2008, 8:09 pm | #13 |
Sorry I'm a little late catching this one - been out of touch for a few weeks.
For the record, I've stripped a Little Maestro Bakelite cabinet using Nitromors and I found the underlying Bakelite surface to be perfect with a brilliant gleam. So I'd say Nitromors is OK in my experience - but ensure a really thorough washing, especially in recesses and inside angles. You can clean with meths, which should help neutralize the stripper action - but I'm sure that others more knowledgeable than I can comment on this point. Stubborn paint in corner angles can be persuade to release its grip using matchsticks (Swan pipe-smoker's or cooks long matches are easier to hold, de-headed of course!). Sharpen the ends into required shape and work the stripper into the resistant paint with the stick ends. Good luck. -Tony |
11th Jul 2008, 10:23 pm | #14 |
Thanks again for everybody's help, will try to strip & clean in one go this weekend, will go & get a small tin of nitromors tomorrow, will post pictures when done.
Mark |
22nd Jul 2008, 9:32 pm | #15 |
Keith,
There is a thread in the archive for this section dealing with this type of paint finish; https://www.vintage-radio.net/forum/...crackle+finish Regards,
Brian |
22nd Jul 2008, 9:49 pm | #16 |
