Old 28th Jul 2019, 7:13 pm   #1
shi12345
Default Help required with the wiring of a Bakelite 232
Hi
I recently acquired a 232 and a 162 at an auction. After looking at the insides it seems the 162 has been wired as a 232, and the 232 has been wired as a 162. I have changed them back to how I believe they should be, but I am encountering quite a few problems with the 232.
The dial tone does not stop when I press the receiver down, also it does not dial out. I spent most of last night studying various photos, but alas I am stuck. No combination seems to work. Please could anyone please explain where each wire should go.
I have orange/blue/grey/brown/pink from the dial, and red /green/brown from the receiver.
Thank you so much in advance
Shi
shi12345 is offline
Old 29th Jul 2019, 10:54 pm   #2
russell_w_b
russell_w_b's Avatar
Default Re: Help required with the wiring of a Bakelite 232
I attach the following drawing from 'Atkinson' although it doesn't show the colours used. But you can check the connections go to the correct terminals. I modded the drawing a little for conversion. It might help.
Kind Regds,
R.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
