Old 8th Dec 2018, 10:47 am   #1
crackle
Default Can you name this?
Please can anyone tell me what is this item called, in English?
Thanks
Mike
crackle is offline
Old 8th Dec 2018, 11:15 am   #2
radioman
radioman's Avatar
Default Re: Can you name this?
According to Google-translate, from your picture title it's a "military two-way radio-leaf antenna"
Andy
radioman is offline
Old 8th Dec 2018, 11:18 am   #3
G4XWDJim
G4XWDJim's Avatar
Usually called a tape aerial.
Jim
G4XWDJim is online now
Old 8th Dec 2018, 11:19 am   #4
G4YVM David
G4YVM David's Avatar
Yes, looks like a flexible folding aerial. We fit them to our EPIRBS on the planes so the hosties don't poke eyes out but can't get the extension wrong either.
Also tape measure aerials for amateur radio kit
Thats what it looks like anyway, as far as my eyes can tell
G4YVM David is offline
Old 8th Dec 2018, 11:33 am   #5
Station X
Station X's Avatar
Jim
Presumably because it resembles a retractable tape measure?
Graham. Forum Moderator
Station X is online now
Old 8th Dec 2018, 12:40 pm   #6
G4YVM David
That and the fact that they are often made from the same stuff. In amateur circles, EXACTLY the same stuff.
Old 8th Dec 2018, 12:41 pm   #7
G4YVM David
https://goo.gl/images/hZPzn2
Old 8th Dec 2018, 12:48 pm   #8
ex seismic
As a type they have been used since the Vietnam war by US military radios and nowadays are commonplace on all sorts of military VHF radios. To identify further we need a close up of the end. Be warned if you take the rubber band off they can spring straight quite violently!
Gordon
ex seismic is online now
Old 8th Dec 2018, 1:11 pm   #9
Station X
Station X's Avatar
I'm sure I remember these being fitted to SARAH Search And Rescue And Homing beacons.
The length of the OP's example would give an idea of frequency.
Old 8th Dec 2018, 5:30 pm   #10
ex seismic
Mil VHF is typically 30-75 MHz, the aerials are fixed length and any tuning is done within the radio, not by the operator. I would expect an overall length in the order of 1.2m.
Gordon
Old 8th Dec 2018, 5:38 pm   #11
G6Tanuki
G6Tanuki's Avatar
Those style of 'tape' aerials were also one of the options for the UK/PRC344 "military airband" [225-400MHz] radios.
There was even a Discone version!
G6Tanuki is offline
Old 8th Dec 2018, 6:32 pm   #12
crackle
Thanks for all your inputs, so the correct name would be a "tape aerial"
Is it intended to retract into a coil like a tape measure for transportation and storage?
Mike
crackle is offline
Old 8th Dec 2018, 6:52 pm   #13
G6Tanuki
G6Tanuki's Avatar
They're not usually coiled-up for storage, more usually they are folded back on each-other a couple of times and either tied, or sometimes pushed into a short length of plastic tube for storage.
The 'springiness' is not designed to make storage easier, it's to provide resilience against accidental damage during the heat of battle!
G6Tanuki is offline
