Old 7th Oct 2016, 5:00 pm   #1
Aubade65
Default Regentone A133 Cabinet Finish
I am in the process of restoring a Regentone A133.
I have found that the cabinet seems to be fairly well made with a nice veneer that seems to have been sprayed with a single coat of a light brown varnish. This varnish could be easily removed by scratching it with a thumbnail so as the painted side panels were not in a very good condition I decided to strip the whole cabinet and revarnish/repaint it.
I was surprised to find when I removed the speaker grill and the plastic surround around the speaker/dial aperture that the cabinet seems to have sprayed with the brown varnish with these two items in place - was this part of the design or did the assemblers run out of varnish and sprayed it at a later date?
I am now in a position to reassemble the set, I have respayed the speaker grill with an antique gold finish insted of the original muddy brown (there was the remains of agold anodised finish underneath) but I do not know what to do about the plastic aperture trim - if it was really intended to be sprayed with brown varnish then I will leave it as it is or should the varnish be removed to leave the trim in its original white finish (the plastic is in good condition)?
Aubade65 is offline
