27th Aug 2016, 6:30 pm | #1 |
Air brush advice needed.
I've never used an air brush. I am thinking about buying one for very minor Bakelite repair painting. I don't want to fork out a lot for an air compressor. Are any available to run off air duster tins? I will only use it about once a year if that. I use car paint aerosols but I need the jet to be a lot more controllable. What would you recommend ?
TFL, John. |
27th Aug 2016, 6:51 pm | #2 |
Re: Air brush advice needed.
Yes they are available for use with an 'air can' pop to your local model shop.
27th Aug 2016, 6:59 pm | #3 |
Thank you, Sound like what I need. It's a lot easier for me on Ebay, I will have a look.
John |
27th Aug 2016, 8:03 pm | #4 |
'Badger' used to be the most common, good, brand.
27th Aug 2016, 8:52 pm | #5 |
Halfords sell 500ml cans of propellant. A can lasts ages:
http://www.halfords.com/motoring/pai...opellent-500ml To be honest, to get really excellent results an expensive airbrush and purpose-designed small airbrush compressor is called for, but for what we're trying to do, with our limited expertise, and occasional use, an e-bay hobbyist one is fine. You'd probably be best using water-based acrylic paints, and Boyes (Holderness Rd/Hessle Rd/Beverley etc), carry an extensive range of colours, which you can mix if you wish. You can also spray clear gloss acrylic. The attached pic of a KB 'Toaster', the cabinet of which had been trashed and I repaired, was sprayed with an airbrush using Boyes acrylic paint as I couldn't find the desired green colour in aerosols. It isn't as garish as it looks - it's 'eau de nil' and the colour was chosen by my son - not me. (He wanted one that colour, so I found a 'scrapper' and restored it for him). If you want to borrow my air brush John to have a go with it to see if it produces the desired results, you're most welcome - just give me a call. Otherwise, if you want to jump in and buy one anyway, those at the link below are typical sub-£20.00 B.I.N. hobbyist ones from UK suppliers: http://www.ebay.co.uk/itm/Dual-Actio...-/161759814436 http://www.ebay.co.uk/itm/Silverline...3D161759814436 Hope that helps a bit. Have fun!
28th Aug 2016, 10:56 am | #6 |
Tasty work David .... I wish your Son had nudged me when I did mine [looks like a Duck laid it]!
Red to red, black to black. Throw the switch and stand well back! |
28th Aug 2016, 5:16 pm | #7 |
If you don't want to pay for the cans they work fairly well when fed from a car tyre.
28th Aug 2016, 6:45 pm | #8 |
I have an image of taking the wife's MX5 upstairs to the workshop. Cans do last a while for most jobs BTW.
28th Aug 2016, 6:46 pm | #9 |
What sort of air pressure do these air brushes work at? I have a general purpose compressor, but never though of using it with an air brush.Ted
28th Aug 2016, 7:22 pm | #10 |
A few tens of PSI, it's all adjustable.
28th Aug 2016, 7:58 pm | #11 |
