18th Jan 2015, 3:17 pm | #1 |
Breeze Connectors - Sizes?
Hi All
I'm looking for information on the physical sizes of the Breeze connectors used on RAF equipment in WW2. These are the circular multi-pin types with flange mounted chassis bodies and cylindrical free connectors. I only need a few major dimensions. The ultimate would be a Breeze document with drawings in but individual dimensions would be OK. I know I will be needing more in the future but this photo shows 6 off as a starter! Any info would be great! Thanks James |
18th Jan 2015, 6:26 pm | #2 |
Re: Breeze Connectors - Sizes?
I've never heard of Breeze connectors but these look like what I've normally known as W connectors.
I have an RF unit with one on and I could measure that if you like. Same as on a WS46, oddly. I also have a somewhat butchered R1355 so if the sockets are intact I could measure that too. Attached image is of text from a Gee manual. Graham
Half my stuff is junk - trouble is, I don't know which half! |
18th Jan 2015, 7:38 pm | #3 |
Breeze connectors and W-connectors are quite different. The ones James has shown on his SBA junction box are indeed Breeze connectors, whereas those on the GEE system are W-connectors.
Breeze connectors are quite elusive for some reason, whereas W-connectors are relatively easy to find. Andy |
18th Jan 2015, 11:19 pm | #4 |
Thanks for the clarification, Andy.
Any examples of equipment using them? Graham
19th Jan 2015, 10:07 am | #5 |
Graham,
W-connectors were used mainly on British radar equipment, for example H2S, and GEE as you already know. Also on some comms equipment such as the TR1196. They are also seen on US equipment which was intended to be compatible, such as the SCR-522 VHF Tx/Rx and early Loran units. An example of a system where Breeze connectors were used was the Standard Beam Approach landing aid, the picture shown by James is part of SBA. However they were extensively used in aircraft looming, certainly in the Lancaster and I assume in other aircraft of that era. Where cable looms passed through bulkheads or frames, Breeze connectors were used. This is not surprising as I remember reading (but can't remember where) that Breeze made up complete wiring looms for fitting to the Lancaster. I believe Breeze were an American company, but I guess must have also had a UK manufacturing side? I've also seen Breeze connectors used on later aircraft equipment, for example I have a rotary inverter and its regulator unit which was part of the Ranging Radar fitted to the Hawker Hunter. The interconnecting lead between the inverter and the regulator uses Breeze connectors, but the connector to the radar system is then a Plessey type! Andy |
19th Jan 2015, 10:26 am | #6 |
Hi
I have found an AERCO catalogue that links 'standard breeze' with AB's AB06 (patt 105) range. I suppose that it might be possible that companies may have copied and carried on the design under another name when Breeze went under. James |
19th Jan 2015, 10:44 am | #7 |
James, that sounds very interesting! I've never seen a catalogue showing Breeze types.
Any chance of a scan? Many thanks, Andy |
19th Jan 2015, 11:44 am | #8 |
Hi Andy
There was only a text 'link', nothing in the catalogue supports this statement and of course I don't have enough detail about the Breeze connectors to confirm/refute any similarity. This is the link to the AB Connectors list of catalogues. http://ttabconnectors.com/index.php?page=connectors You can jump to the catalogue from here and see the drawings it holds. This is the sort of catalogue that I was hoping might be available for the Breeze range. Judging only from the design of the 90 degree elbow for the free connector it doesn't seem that there is any correlation though. The AB05 and 06 range conform to MIL-C-26482, I wonder (hope) if this was the designation for the 'Breeze' range or if the range spawned this number. Cheers James |
19th Jan 2015, 1:39 pm | #9 |
The MIL-C-26482 is still readily available and is used on military and broadcast equipment http://www.amphenol-aerospace.com/pdf/12-070.pdf as are the similar MIL-C-38999 http://www.amphenol-aerospace.com/pdf/12-070.pdf but I don't think these ranges are what you are looking for.
PMM |
19th Jan 2015, 3:23 pm | #10 |
There is an important difference regarding Breeze connectors which hasn’t been mentioned so far............
The W-connector was, I guess, one of the earliest types of standardised circular military connector. The shell of the fixed part is threaded externally, to engage with an internal thread in the locking ring which is part of the free part of the connector. The insulated insert which carries the pins in the free part is located in the shell such that it cannot rotate within it, and the locking ring is free to be rotated around the shell. This principle became the usual approach in later types of circular connector, for example the Plessey range, common on military equipment through the cold-war era, and later types such as the MIL-38999. In later types the thread on the outside of the shell of the fixed part is replaced by three small radial ‘pegs’, with corresponding course spiral grooves inside the locking ring on the free part, but the principle remains the same. The Breeze connector is quite different. The shell of the fixed part has an internal thread, and the shell of the free part has an external mating thread. There is no locking ring. The insert in the free part is free to rotate within the shell. So as a connector is mated, once the pins have engaged the insert in the free part cannot rotate, and the shell rotates about it as it is screwed home. This raises an interesting issue if the wires are contained within a screening braid or conduit, attached to the back of the shell with a gland. It is essential that the gland nut is slackened to allow the shell to rotate relative to the braid or conduit when a connector is fitted or removed. I have a short document, A.P.1095, Volume 1, Section III, Chapter 5 “Breeze Screened Wiring System”. It is only a dozen pages, so I can scan it if anybody is interested. Unfortunately it doesn’t answer James’s question regarding connector sizes, it is essentially concerned with techniques used to terminate the wiring in the connectors. Andy |
19th Jan 2015, 8:55 pm | #11 | |
That answers a head scratching niggle I had for a long time, all the Breeze connector junction boxes on the MkI Stirling have a label with a similar warning! Hope you can make it out. James |
5th Apr 2015, 6:29 pm | #12 |
Still digging around for information on Breeze connectors, I've stumbled over another piece of the jigsaw. As is often the case with something like this, with hindsight it's surprising I hadn't come acros it before!
What we know as Breeze Connectors (part of the overall Breeze Wiring System) in the UK were actually made by Plessey, who took out a manufacturing licence from the Breeze Corporation in the US, in 1936. So they can also be referred to as 'Plessey Breeze'. (Note that they are not to be confused with the range of circular connectors commonly described as 'Plessey Connectors' which were used extensively on military equipment during the cold-war era.) Which begs the question, has anybody got any old Plessey catalogues from the 40's or 50's which might include the Breeze range? Andy |
5th Apr 2015, 7:22 pm | #13 |
Hi Gents, no data on Breeze connectors I'm afraid, but I looked up my old 1981/2 copy of the ITT yellow parts catalogue; it is full of a wide variety of connectors form many different manufacturers. I kept it as a valuable cross ref.
Not sure if anyone has an older copy that may have Breeze in it. Ed |
5th Apr 2015, 8:00 pm | #14 |
It might be worth contacting Roy at Electrojumble.
http://electrojumble.org.uk/index.htm Apart from the data on his website, he has a mountain of leaflets/data sheets/catalogues, plus an immense amount of knowledge, and may be able to find the information you require. |
5th Apr 2015, 8:59 pm | #15 |
Good idea, I'll do that. He doesn't list Breeze types on his website, but you're right, he is knowledgeable and helpful, I've bought from him in the past.
Andy |
5th Apr 2015, 11:11 pm | #16 |
Just looked in the big yellow ITT book from about 1977 and the only Plessey ones I can see are Mk 7.
Graham
6th Apr 2015, 12:54 am | #17 |
Graham, thanks for looking.
I don't know when these connectors were considered to be obsolete, but I suspect probably during the 1960's, so we need a catalogue from the 40's or 50's. I've emailed Roy at Electrojumble to ask if he knows anything about them. Andy |
6th Apr 2015, 1:08 am | #18 |
FC Lane mention Standard Breeze on their clearance section
https://www.fclane.com/product-group/plessey-connectors
Kevin |
6th Apr 2015, 9:22 am | #19 |
Kevin,
Yes, I'd spotted that and wondered about contacting them. I've had no dealings with FC Lane, are they willing to talk to folk after information and maybe small orders? I'll phone them after the Easter break. Andy |
6th Apr 2015, 12:05 pm | #20 |
I don't think there's any minimum order but there will be a courier charge. The last stuff I had from there were Weald connectors but that was 10 years ago.
Kevin |
