Old 7th Aug 2008, 9:43 pm   #1
man_of_kent
man_of_kent's Avatar
Default chassis cleaning
Hi all
I was wondering what is the best way to clean the chassis? if it be steel or Aluminium? is it ok to use wire wool or is it best to use an electric brush cleaner or some chemical cleaner thanks all
Brent
man_of_kent is offline
Old 7th Aug 2008, 10:34 pm   #2
Default Re: chassis cleaning
See here:-
http://www.vintage-radio.com/repair-...e-chassis.html
Don't use wire wool. Bits of wire will break off and short circuit valveholders etc.
Station X is online now
Old 8th Aug 2008, 12:14 am   #3
paulsherwin
paulsherwin's Avatar
A lot depends on what the dirt is. WD40 does a good job of dissolving waxy filth. I finish off with T-Cut if I'm really serious about cleaning things.
I don't normally bother doing this though, as you need to remove pretty much everything from the chassis to do the job properly. A 60 year old chassis should *have* some dirt
Paul
paulsherwin is online now
Old 8th Aug 2008, 1:41 pm   #4
man_of_kent
Thanks chaps I will check that out station x also Paul I had this idea the chassis was supposed to shine like a restored car engine it is more than dirt in some cases it looks like damage to the surface like black spots especially on the steel the best way to describle it would be to say "blotches" but another question or two what is the best thing to use on a speaker cone that has a hole in it and is there any need to worry about bits coming off the mains dropper as the wire is showing?
Thanks...ps I do need to make more use of this site
Brent
Old 8th Aug 2008, 6:06 pm   #5
Dave Moll
Dave Moll's Avatar
Originally Posted by man_of_kent View Post
what is the best thing to use on a speaker cone that has a hole in it?
Some thoughts on this here. For further discussion of speaker cones, please start a new thread.
Dave Moll is online now
Old 8th Aug 2008, 8:32 pm   #6
Nickthedentist
Nickthedentist's Avatar
See this thread for some very imressive chassis renovation: https://www.vintage-radio.net/forum/...ead.php?t=9948
Nickthedentist is offline
Old 8th Aug 2008, 10:58 pm   #7
Neil F
Neil F's Avatar
I'm no expert on the following, and I'd be pleased to be corrected, but from what I've read in other threads about chassis cleaning I'd be a bit wary about using mechanical aids like a wire brush or sandpaper to clean chassis - old ones, anyway. Older chassis are sometimes cadmium plated, and as I understand it cadmium is a toxic metal that you don't really want to be turning into dust and inhaling.
Neil F is offline
Old 8th Aug 2008, 11:23 pm   #8
Sean Williams
Sean Williams's Avatar
Yep, Cadmuim is not good for you, fortunately, not used that often on domestic equipment, but best to be careful!
Sean Williams is offline
Old 9th Aug 2008, 8:57 am   #9
Mike Phelan
Mike Phelan's Avatar
Here are some before-and-afters of my Fergy 378U - the chassis was stripped and shotblasted, and the IF cans had a trip to the dishwasher.
I did not use any sort of abrasive anywhere.
When it's complete, I'll post a thread in Success Stories, but that will give you some ideas.
ID:	19037   Click image for larger version
ID:	19038   Click image for larger version
Mike.
Mike Phelan is offline
Old 9th Aug 2008, 10:00 am   #10
Don Collie jnr
Hi Brent,
I usually fill the bath with hot water, and add some floor cleaner. You must dry the chassis *thoroughly* in warm air though. I remove meters, and speakers etc. though.
I`m not kidding! This method produces good results.........................................Do n.
Don Collie jnr is offline
Old 9th Aug 2008, 12:08 pm   #11
Nickthedentist
Originally Posted by Mike Phelan View Post
...the chassis was stripped and shotblasted, and the IF cans had a trip to the dishwasher.
How did you achieve that, Mike? Did it cost much?
Nick.
Old 9th Aug 2008, 12:36 pm   #12
Mike Phelan
It was free, Nick, as a pal works in an engineering works and I had a few other things to blast as well. It did not remove the plating, either, as far as I can tell. It might have been cadmium; not sure of that.
Mike.
Old 9th Aug 2008, 6:06 pm   #13
man_of_kent
Thanks so much for those warnings I had no idea about what can happen if you go about cleaning the wrong way I am very impressed with the results you chaps have all shown in your pics here with different cleaning methods and I did try boot polish on my DAC90A case (not chassis lol) as I had spoted it on an other thread and saw those lovely cabinets shine so I gave it ago .. cheers for that chaps.
Brent
