28th Dec 2010, 12:56 pm | #1 |
Valves
I have a list of valve and i whish to do something with them what can i do with them.
G.e.c. X119 b109 w.119 u119 dh109 thanks chris |
28th Dec 2010, 1:47 pm | #2 |
Re: Valves
X119 = UCH81
U119 = UY85 B109 = UCC85 W119 = 10F18 DH109 = UABC80 Must have come from an AC/DC set. |
28th Dec 2010, 2:17 pm | #3 |
Re: Valves
The difficulty with using these valves for home projects is that they have nonstandard heater voltages, since they were designed to be used in a 100mA series heater chain. The W119 is an RF pentode with a 13V heater and could be used to build a one valve radio using one of the many circuits available (e.g. here). A 12V supply should be adequate for the heater. The X119 could be used to build this MW microtransmitter if you can find a 19V heater supply.
If you can find a 40V heater supply you could use the 10F18 and DH109 to build a 2 valve radio, wiring the heaters in series. |
28th Dec 2010, 2:45 pm | #4 |
Re: Valves
Or you could flog or swap them for some E series valves with a 6.3V heater.
In fact if you fancy it PM me I could do with some U series valves for stock and have loads of E series stuff which would be good for experiments. Jay
The light at the end of the tunnel is probably the headlight of an oncoming train |
28th Dec 2010, 6:02 pm | #5 |
Re: Valves
28th Dec 2010, 7:59 pm | #6 |
Re: Valves
So... build an FM/AM radio! For safety use a 240V iso TX and a capacitor dropper for the heater chain.
28th Dec 2010, 8:08 pm | #7 | |
Re: Valves
thanks for all you help.
thanks chris |
28th Dec 2010, 8:13 pm | #8 |
Re: Valves
i fogot to mention that that is the set they are from as i got givin it but the case was all smased up.
