Old 25th Oct 2015, 2:04 pm   #1
cinema1
Default Active Antenna 1-30MHZ
Hello ,
Can any one help with the following---- I've built a ACTIVE ANTENNA Frequency 1---30MHZ , Using a small ear -piece to ear for radio signals all
i get is a noise in the ear- piece. All the voltages are correct to circuit info, my antenna is a piece long wire 18" long.
kind regards.
cinema1
cinema1 is offline
Old 25th Oct 2015, 2:19 pm   #2
Default Re: Active ANTENNA 1-30MHZ
Circuit diagram, photos, all of these will help us. The information given so far is much less then needed for a proper diagnosis.
Old 25th Oct 2015, 3:48 pm   #3
Ed_Dinning
Default Re: Active Antenna 1-30MHZ
Just a thought, but have you got the earpiece plugged into the active aerial or into a set that is fed by the active aerial?
Ed
Ed_Dinning is offline
Old 25th Oct 2015, 5:53 pm   #4
Herald1360
Herald1360's Avatar
An active antenna isn't in itself a radio. It's a name given to an aerial (usually a shortish whip) that has active electronic circuitry to convert the signal from the whip- a source of indeterminate and highish impedance- to a low impedance (50-75 ohm) suitable for feeding a typical communications receiver.
A good one isn't a trivial design exercise- the electronics has to handle a broad frequency range and cope with high level signals without overloading and generating spurious outputs whilst also passing other low level signals cleanly.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
