Old 13th Jul 2005, 1:08 am   #1
Kim
Default Circuit diagram Laney L100PA amp needed
Hi, I have a great Laney L100PA Amp that needs some attention to the output valve circuit. Does anyone have a circuit diagram for this? It sounds tremendous when it is working - loads of eq and inputs and presence. The whole amp is built to a very high standard it seems but someone has mucked about with the valves and it needs to be rewired properly. I think it may have been manufactured in the 70's.
Kim is offline
Old 13th Jul 2005, 1:04 pm   #2
Chris_C
Chris_C's Avatar
Default Re: Circuit diagram Laney L100PA amp needed
Have a look at: http://www.freeinfosociety.com/elect...page.php?cat=1
While the L100PA is not listed, there are several 100 watt valve amps all with similar output stages. One of them might suit you.
Chris C G8TJR
Chris_C is offline
Old 13th Jul 2005, 11:45 pm   #3
Kim
Thanks Chris that is very helpful. I shall take a good look at these and let you know how I get on.
Kim is offline
Old 14th Jul 2005, 9:05 am   #4
mikelect
mikelect's Avatar
Try this although you will have to pay!!
http://www.majelectronic.co.uk/
Mike
mikelect is offline
