14th Jun 2017, 7:11 pm | #1 |
Making A Pre-War Style Television?
Down at my local charity shop there are around 4 televisions, 2 of which are the cheap 1980s type b/w 5 inch screen type. I wondered if I could take one of these, remove the internals and mount them in a wooden cabinet, and replace the controls with old radio knobs. Make it like the HMV 905.
What do you think, I mean it's not like we can easily get pre war sets. Thanks, Jake |
14th Jun 2017, 7:23 pm | #2 |
Re: Making A Pre-War Style Television?
Would be a real fun project. But why not consider making a mirror lid television? Cabinet would be easier to construct.
DFWB. |
14th Jun 2017, 7:29 pm | #3 |
I would do a mirror lid, however I'm 15 and I don't think my parents would be too happy to have a great big television in my room. Plus I don't mind the wood work I do it in my spare time anyway and I'm fairly good.
Thanks for the suggestion. |
14th Jun 2017, 7:36 pm | #4 |
If it's like the little 5" monochrome TVs that Maplin sold, then I can offer a few hints, as I've been inside and repaired that model.
There are 2 tuning knobs, one for the radio funtion (tuning capacitor), the other for the TV function (potentiometer, controlling a varicap tuner module). Two PCBs. One horizontal with all the TV circuitry and audio amplifier on it, the other vertical with the radio stuff on it. You could completely remove the latter if you didn't want the radio function. And you can extend the leads to the TV tuning pot to any (sensible) length. IIRC there is a volume control on the TV PCB, you could mount this elsewhere in the cabinet and would probably have to extend the leads with screened cable. Three presets on the back, also mounted on the TV PCB -- brightness, contrast, vertical hold. No idea how they would take to being moved off the PCB on longer wires. If you mount the CRT vertically and make a mirror lid set (what will you use for the mirror?) you would have to reverse one of the deflections (which one depends on which way round you mount the CRT). You can do this by swapping the appropriate wires on the yoke. Being monochrome there is, of course, no convergence, etc to worry about. IIRC the ICs used in this set do have available data sheets so it wasn't hard to work out what was going on. |
14th Jun 2017, 7:46 pm | #5 |
Thanks Tony but i'll just make the 905 type set as I do not have room for a larger set, however your advice is still valued for the smaller set.
Thanks, Jake |
14th Jun 2017, 9:54 pm | #6 |
If it's the type of TV I'm thinking of, with a little mono screen about 14 cm., a battery compartment underneath and a built-in radio, you should be able to modify it easily enough to be able to feed in baseband video and audio. Then you could add a set-top box, or use something like a Raspberry Pi to play suitable programme material through it.
PoundWorld have some rectangular wooden-framed make-up mirrors that you could cannibalise one of to make a replica mirror-lid set. Fun quiz time: What could you do to the set, that would reverse the picture on the tube so the reflection was the right way around?
14th Jun 2017, 10:33 pm | #7 | |
No Longer a Member
You are quite right about that. In fact it has been estimated for some American pre-war sets there are only numbers left in the range of 11 to 20 sets of some types and for the HMV904 or similar perhaps about 40. This makes many pre war sets rarer than any violin made by Stradivari. It is in fact possible to build a replica that is pretty darn close, it has been done here in Australia by Mr Victor Barker: http://www.earlytelevision.org/barke...4_replica.html (obviously we do more than drink beer down here) But that of course does require a substantial working knowledge of vacuum tube & television technology which takes a while to acquire. However, it can initially give you an inspiration for the cabinet and dial. The dial was created from a scan of an original 904. There would certainly be plenty of room in a 904 cabinet to fit a TV set based on modern electronics. When I was your age (back in the late 1960's) I became enamored with pre war television too, especially the articles on how to build TV's with oscilloscope tubes like the 5BP1 as the pre & post war versions of these were essentially the same. There were a number of articles published, including a very good one from Australia in Radio Television & Hobbies Sept 1957, here is a link to a built one: http://members.iinet.net.au/~cool386...0receiver.html Finally after many years I got around to building Practical television's Argus: http://worldphaco.com/uploads/ARGUS.pdf I think it is admirable that you are interested in pre war television and the interest will take you on a great journey. |
14th Jun 2017, 11:20 pm | #8 |
I dismembered one of those little sets, with the same end in mind- they're quite demountable, with a compact board and a separate carrier for the tuning knob etc. mine had an RCA video input, I seem to remember. Rotten little speaker, you could include a small amplifier and a larger speaker in your 'hack'.
I never got any further than extending the necessary leads on mine, although I still have the 'tube somewhere. I quickly became dissatisfied with the cosmetic approach, and marked upon building a pre-war style console set from scratch- although I'm still a long way off completing that! I sometimes think about picking up another of these little B&W sets to make a mini working model of the Marconi 702, but that may never happen.. Oliver |
14th Jun 2017, 11:29 pm | #9 |
15th Jun 2017, 4:53 am | #10 | |
I thought the mirrors in mirror-lid TVs were front-silvered to avoid multiple reflections. A 'normal' mirror might produce such reflections which would look horrible I think. As for reversing the picture, didn't I comment on this in my earlier post? Just swap over the leads to the appropriate deflection coil. |
15th Jun 2017, 5:48 am | #11 |
I have made such TVs myself using wooden bread bins. The effect is quite pleasing.
Many of those 5.5" TVs have A/V sockets on the back, which avoids the need for a UHF modulator. The brilliance / contrast controls are presets on the rear. It is straightforward to replace these with proper controls. Assuming you're modifying a monochrome TV, the HT is about 80...100V and is not too dangerous but I did get a nasty surprise when a whisker of wire pierced my skin The EHT can give you a nasty jolt too - do be careful if you disconnect the tube from the PCB - the EHT can linger for quite a while and can get you when removing the anode cap. I always connect a slim screwdriver to the tube earth connection (often no more than a strip of metal pressing against the flare) using a croc lead. I then slide the end of the screwdriver under the anode cap and wait for the telltale 'crack!'. I tried to make a miniature Predicta using one of those TVs. Disappointing. It rather less resembled a Philco Predicta than it resembled a cheap 5.5" telly tube on a box. The tube is simply too deep to retain proportions. |
15th Jun 2017, 2:07 pm | #12 |
Hi Jake,
I actually converted one of those 5" Maplin sets to be dual standard, ie 625 and 405. I didn't invert the video detector to make use of its VHF capable tuner, mearly used it with with the AV inputs. The linearity on 405 was not great, but is was used for basic picture comparisons between 625 and 405 line signal sources. Cheers Andy
www.youtube.com/user/andyvalve100 |
15th Jun 2017, 3:52 pm | #13 |
I very much like the idea of a mirror lid 5" scale replica. It's almost perfect for the relatively long CRT used in those portables. Enough room for a DTV converter and batteries too.
Oh no, I have started another project in my head. |
15th Jun 2017, 4:46 pm | #14 |
Hi.
What a great idea for a project. I have several 5" monochrome sets. I picked up two for £3 at the local car boot sale last year. One is a Deccavision made around 2000 and could be a good candidate to convert as the plastic cabinet is cracked and not worth fixing. The set had a frame fault due to duff dried out electrolytics which is now working fine. One of many projects to undertake, the problem is finding the time what with pressures of modern day life. Regards Symon. |
15th Jun 2017, 4:49 pm | #15 |
15th Jun 2017, 5:37 pm | #16 |
I made one of those TVs work on 405. I first attacked the time constant of the line oscillator so that it could lock to 10.125kHz. This would lead to overscan and excessive EHT so I disconnected the line output supply before starting. I then powered the line output from a bench supply and brought that up until the line width was right. This worked but the EHT ended up on the low side resulting in a dimmish picture. But then it's an old, tired tube, isn't it?
Another issue is self resonance of the LOPT which should be three times the line frequency. When it's not, there may not be full energy recovery and consequent low efficiency. In practise, I didn't find this to be a problem. The final step was to add a regulator to supply the new, lower power rail for the line output section. |
16th Jun 2017, 12:30 am | #17 |
Hi Symon,
I didn't bother with correcting the third harmonic tuning, though that might have solved the linearity problem. I basically did exactly what Karen has just described, using an LM317 to drop the supply to the line output stage to about 7.5 volts IIRC (it was maybe 20 years ago now). The EHT seemed ok on my set though. I then fitted a double pole relay activated by a latching push switch. The relay changed the time constant of the line timebase and of course switch in the LM317 for 405 line mode. Cheers Andy
16th Jun 2017, 10:58 pm | #18 |
Hi Andy.
Very interesting, so it shouldn't be too difficult to get the line output stage to work at 10.125kHz. Thanks for the info, when I find the time I'll do some experiments on my little Decca set. Regards Symon. |
17th Jun 2017, 11:37 pm | #19 |
Hi Jake,
if you are going to make a prewar TV, I would advice you to make a caricature of a historic set rather than trying to make a replica. Now that's a bit of an ask with a wooden box or console, or even the styling of an HMV905, but here's my suggestion, not pre war though and not even British. Reassemble a modern CRT mono (or even colour) set into a a caricature of a Philco Predicta. |
