Old 6th Jul 2019, 1:14 am   #1
radiograham
Question UHF tuner use.
Hi I am hoping someone can advise me about this,i have a uhf tuner u943c made by Philips i think.This is the tuner sold by Maplins and used in their Nicam tv tuner in feb/mar 1990 magazine.This is meant to be fed to a saw filter,i was hoping to use it with a valve if strip but not having much luck.Can anyone tell if me if it's possible to use it in this way or am i wasting my time? Graham.
radiograham is offline
Old 6th Jul 2019, 9:45 pm   #2
Restoration73
Restoration73's Avatar
Default Re: UHF tuner use.
In general, any varicap uhf tuner has a lower gain compared to a mechanical type, and even that often used the vhf tuner (on a 405-625 set) switched to "U" to give additional
IF gain. Therefore you may need an outboard IF preamp based on a transistor or MMIC
to overcome the losses. This site gives excellent background development of tuners;
https://www.maximus-randd.com/tv-tuner-history-pt4.html
Restoration73 is offline
Old 7th Jul 2019, 3:25 pm   #3
Nuvistor
Nuvistor's Avatar
RBM used transistor or valve UHF tuners straight into the IF strip in their Bush TV125U and TV135RU televisions. The 125 used EF85/80’s the 135RU used EF183/184’s.
Others makes used the VHF Mixer for extra IF gain, perhaps if you look at Bush circuits it may help.
Frank
Nuvistor is offline
Old 7th Jul 2019, 11:49 pm   #4
radiograham
Hi,i was wondering if this tuner which is fed into a saw filter rather than a conventional if strip whether the if output would be suitable for use with a valve if strip. Graham.
Old 8th Jul 2019, 12:51 am   #5
Nuvistor
Nuvistor's Avatar
Direct drive SAW filter Tuner units such as the u943 have a low impedance output, this will need matching to the IF strip, some valve iF inputs probably have a much higher impedance although those Bush tuners were fed by 75 Ohm coax.
You could possibly cure two problems with a transistor matching stage between tuner and IF, it will give some extra gain and match the units.
The matching is the problem you have to solve.
Frank
Nuvistor is offline
Old 8th Jul 2019, 2:33 pm   #6
G6Tanuki
G6Tanuki's Avatar
Yes, the impedance-matching is likely to be an issue!
Either use a tuned-circuit with a tapping for the input, or maybe consider using an emitter-follower. Do you know the impedance of the SAW filter the tuner is designed to drive??
See fig.4 here:
https://www.robkalmeijer.nl/techniek...e71/index.html
for an idea though when I've done this for HF-band crystal filters (either homebrew ones using ex-TV crystals or commercial KVG ones) my trick has been to remove what's shown as "Rterm" and then replace what's shown as the two 22K base-bias resistors with a pair of resistors each double the value of Rterm.
G6Tanuki is offline
Old 10th Jul 2019, 1:58 am   #7
radiograham
Hi thanks for all the help,not had a lot of success using this tuner for anything other than its original purpose ie with a saw filter,in this it works fine.Think i need to find an earlier type. Graham.
Old 10th Jul 2019, 7:32 am   #8
Nuvistor
Nuvistor's Avatar
Is the IF strip home made or from an old TV set and by not a lot of success do you mean poor pictures or it just doesn’t work?
Frank
Nuvistor is offline
