22nd Dec 2012, 5:27 pm | #1 |
Substitute mounting for SC12 cartridges.
Sorry if this has been done before, but thought I'd share my version. The SC12H is a popular choice for a replacement cartridge and I happened to have two in my bitbox, but no clips. I wanted to use them to replace two dead Garrard GC8s. With a little bit of thought (not too much!) I was able to mod the fixing brackets from two dead BSR TC8 cartridges. This allowed me to: 1. Use the twin hole mount in the Garrard headshell. 2. To "bodge" a fixing for the turn-over knob so that, from a distance, it looks reasonably original. 3. To play stereo records without damage. On the BSR bracket there are two tapped holes. I drilled out the rearmost one and elongated it a bit. I then used a small screw with two nuts through this hole and screwed it in to the hole on the top of the SC12H. Using a small pair of forceps I gently tightened one nut upwards to lock the screw to the bracket, and the other nut downwards against the cartridge. (Don't tighten it too much as it's very easy to strip the thread in the cartridge!) I did this as I didn't have a suitable spacer. Be careful not to insert the screw too far into the cartridge as this will damage the ceramic elements. Then the bracket is fitted to the headshell as normal. In the Garrard headshell there is a hole between the fixing points and this will accomodate the centre screw head. It works a treat and yours truly is quite chuffed with the results. Cheers, Pete
22nd Dec 2012, 5:53 pm | #2 |
Re: Fakin' it!
Nice work, thanks for sharing!
22nd Dec 2012, 10:14 pm | #3 |
Re: Substitute mounting for SC12 cartridges.
Thanks for changing the title, Mods. I intended to change the "working title" before I posted it, but failed so to do. I tried afterwards, but couldn't. I presume a title can be changed after posting, but don't know how to do it. Sorry chaps. Cheers, Pete
22nd Dec 2012, 11:15 pm | #4 |
A good job well done, a little thought goes a long way
I have managed to rebuild one of those horrid Philips heads with the cartridge from a cheap 90's midi system! Mark |
23rd Dec 2012, 1:26 am | #5 | |
We edit titles frequently, mainly so the threads concerned can be found by search engines. We do appreciate it's not always easy to come up with a suitable title; indeed I changed the title of this thread myself - but only after scratching my head for a couple of minutes to come up with something concise. |
23rd Dec 2012, 12:27 pm | #6 |
Thanks Darren, much appreciated. Cheers, Pete
29th Dec 2012, 3:54 pm | #7 |
Brilliant and noted for future modifications. Many thanks for sharing.
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
14th Jan 2013, 12:08 pm | #8 |
Great work!
Somewhere I have pics of a similar thing I did with a philips AG3302 and a Sonotone 3509.
Regards, Ben. |
14th Jan 2013, 8:45 pm | #9 |
Novel solution. Nice to keep the original look too!
Radio Tircoed - Working for the Community |
