8th Oct 2014, 11:20 pm | #1 |
Metal Epoxy
Hi all,
Just repaired a broken stud on the front panel of my AR-88 using this stuff :- http://cpc.farnell.com/evo-stik/8085...tt=metal+epoxy Instructions say leave for 10 minutes before handling once applied, after half an hour the bond is strong enough to withstand picking the whole thing up from the repaired stud. Hope this is of use to someone. Cheers, Kev |
9th Oct 2014, 10:28 am | #2 |
Re: Metal Epoxy
Noted,
Many thanks
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
9th Oct 2014, 8:03 pm | #3 |
Re: Metal Epoxy
The 'thing' being the front panel or the whole AR88 ?
B
9th Oct 2014, 8:36 pm | #4 |
Re: Metal Epoxy
Many people swear by something called J B Weld. A metal loaded epoxy paste that does what it says on the tin.
10th Oct 2014, 10:45 pm | #5 |
Re: Metal Epoxy
I've used J B Weld, loaded with Steel, works a treat
David |
12th Oct 2014, 9:34 pm | #6 |
Re: Metal Epoxy
The Aluminium-loaded JB Weld is good stuff too - I've used it to rebuild the control-harness terminal box on an antenna-rotator.
The JB Weld is quite good enough to be drilled/tapped and take screws once it's fully hardened. |
21st Jan 2015, 6:39 am | #7 |
Re: Metal Epoxy
I use epoxy sealant, available in dual-component lump form, to rebuild broken moulded parts. It's also referred to as epoxy putty and branded as 'M-Seal', 'Araseal' etc. Available in quick-setting (1 hour) versions too. Can be cut, filed and polished to shape.
Regards, Nandu.
https://nandustips.blogspot.com |
8th Feb 2015, 7:17 pm | #8 |
Re: Metal Epoxy
Yes JB Weld And Super Steel both excellent if expensive, pity the CPC stuff isn't any cheaper
9th Feb 2015, 12:33 am | #9 |
Re: Metal Epoxy
Belzona 111 is another similar product, again it is expensive for some jobs but may save £1000s in industry. I've used it and very pleased with it. And I believe it is made in the UK.
John. |
