Old 2nd May 2020, 2:52 pm   #361
qazxsw123
Default Re: Gemini 80-Bus System
looks like one of the files did not attach, second try
qazxsw123 is offline
Old 2nd May 2020, 3:03 pm   #362
john_newcombe
Originally Posted by qazxsw123 View Post
disk image files for cpm 2.2 bios 3.5 and basic programs
If its OK with you I will stick this up on glasstty.com with the others as it's a QDDS image and I only have bios 1.4 on a DDDS image.
john_newcombe is offline
Old 3rd May 2020, 7:17 pm   #363
JohnBHanson
Just for testing I downloaded it and it works fine under xbeaver with the following configuration
cpuclock
board 0xfe gm813_mmu
board 0xb0 gm832 Gemini_557 green keyboard gemini
board 0xe0 gm849_floppy -geometry 80.2.10.0.512 & ~/beaver/disks/gm557_master.img
binload 0xf000 ~/beaver/rpm-v2p1.rom
byte 0f0a8 21 00 f0 #Patch top of ram for RPM
NB - seems to need a GM849 disk controller.
PS - the command "DIR" with no arguments works fine on the simulator - it lists all files.
JohnBHanson is offline
Old 3rd May 2020, 9:22 pm   #364
john_newcombe
cpuclock
Now that you mention it I vaguely remember reading in one of the 80 Bus News magazines that bios 3.5 needed an 849. I can't remember why though.
Old 3rd May 2020, 9:57 pm   #365
JohnBHanson
Note to those planning to use the configuration - miss the & out of the board line. When I typed it was displayed as two lines and hence the & at the end of the line which indicates a continuation line was needed. However it is now displayed as one line and so the & is not required.
Sorry autoformat causing confusion.
Old 4th Jun 2020, 3:52 pm   #366
Mixtel0
Mixtel0's Avatar
If anyone is interested, I'm currently compiling a "Definitive list" of all the 80-BUS hardware in the Gxxx series on my nascom.info site. It's not that far off complete, but if anyone can help with filling in the gaps it would be nice.
Mixtel0 is offline
Old 4th Jun 2020, 5:28 pm   #367
AdrianH
AdrianH's Avatar
Just catching up on this thread. I have a Chinese Eprom programmer that can be borrowed if required a Genius G540 that I ran under XP connects via a USB lead to the PC, I am sure it would do 2716 and 2732 type Eproms and bigger. I will have to check if it will still run under Win10?
Let me know if interested.
Adrian
Asking questions and learning, or trying to!
Youtube EF91Valve
AdrianH is online now
Old 6th Jun 2020, 11:15 am   #368
Mixtel0
Mixtel0's Avatar
I've just got (but not tested) a couple of AT28C16 EEPROMs. If they work as expected they should make an interesting alternative to 2716 EPROMs as they should be able to be programmed "in situ" by pulling /WR low with a "write protect" switch and repeatedly writing/reading each byte until it reads correctly.
Mixtel0 is offline
Old 4th Aug 2020, 10:14 pm   #369
john_newcombe
JBH:
Hi John, I have finally got round to trying the last Master disk that was posted on the thread and I started by downloading the latest XBeaver. I am having all sorts of difficulties in compiling this against Arch Linux. I know we created an Arch Makefile but this is now out of date with the source files (window.c for example). I am wondering, therefore, what version of Linux you are using and what window manager. I will then replicate the environment here and hopefully it will just build going forward.
Old 5th Aug 2020, 12:17 am   #370
JohnBHanson
I have renamed textwin.c to textwin_X.c and also created textwin_SDL.c and textwin_SDL2.c to allow builds against X and also SDL and SDL2 if they are installed.
Other details in PM.
Old 18th Sep 2020, 10:51 pm   #371
john_newcombe
I have finally sorted out the compilation issues I had and have now tried the disk image and config files with the latest xbeaver, however, I get the following results repeated over and over. Any thoughts?
Code:
    WHAT?
    *8888888888888888888888888888888888888888888888888888888888
    888888888
    WHAT?
    888888888
    WHAT?
    888888888
Old 18th Sep 2020, 11:08 pm   #372
JohnBHanson
What config file are you running?
Also if you are running rpm has the serial port been configured and
if you are using a physical port does the xbeaver program have access to it.
make sure line in config starting
board 0xb8 serial_8250 ....
make sure you have a floppy controller specified
board 0xe0 gm829_floppy ....
Looks like rpm is trying to read from a non-existant serial port
Old 19th Sep 2020, 9:51 am   #373
john_newcombe
I was just using the config from your post 363, although I have selected RP/M 2.3 rather than 2.1. I will investigate further, thanks for your help.
Old 19th Sep 2020, 10:00 am   #374
john_newcombe
Serial port now added and I get to the RP/M monitor, however, RP/M reports the disk posted in post 361 as Bad Disk. Perhaps I have misunderstood what it was that you got working with xbeaver in post 363.
Old 19th Sep 2020, 10:59 am   #375
JohnBHanson
Remember using -v one or more times on the command line gives more tracing (Including disk I/O).
This maybe helpful
Old 19th Sep 2020, 12:51 pm   #376
JohnBHanson
I have downloaded the img file and checked with mine and they compare.
Using the following gem557.cfg
cpuclock 4
board 0xe0 gm849_floppy -geometry 80.2.10.0.512 ~/beaver/disks/gm557_master.img
binload 0xf000 ~/beaver/rpm-v2p3.rom
xbeaver gem557.cfg
boots ok
Old 19th Sep 2020, 9:59 pm   #377
JohnBHanson
Shortly after reset RPM tries to boot the floppy. If this fails it issues
its prompt and then looks for input. This check for input includes
the serial port.
If the boot suceeds cpm performs the io which does not include checking the
serial port for input.
As to the BAD DISK the clue is in the FAIIL - looks like xbeaver cannot read the
floppy image file.
I hope that helps.
Old 19th Sep 2020, 10:04 pm   #378
john_newcombe
I have it, I the file had the extension in lower case and the config did not the -vv option pointed me in the right direction. Many thanks, really appreciated.
What I am hoping is that this image can be used in the Gotek with the MFB hardware to boot the machine (not with MFB bios obviously). Once I have it booting I can start investigating the other issues, e.g. testing the Xebec calls and creating real boot disks.
Old 19th Sep 2020, 10:45 pm   #379
JohnBHanson
I enclose the winchester formatter - which maybe helpful.
Note that the GM849 electronically inverts the data before presenting it to
the zebec controller. This is compensated for by the gemini bios also inverting
the data leaving data on the correct sense on the hard disk.
The xbeaver bios does not invert the data but uses the repeat io instructions
of the z80 to send the data quickly. This leads to much quicker io but the
data stored on the hard disks is inverted with respect to a gemini system.
Also there is a sector size jumper on the zebec controller and this needs to
be set correctly.
Note files are in gemzap format. (xbeaver Needs gemini keyboard option to run - this
can be changed dynamically by pressing and holding the left control key and then press and release the right control key and finally release the left control key. (wordstar keyboard selected by swapping left/right in the above procedure).
Old 20th Sep 2020, 10:24 am   #380
john_newcombe
Thanks, John. I will take a look.
A quick update re Gotek....
I have now booted my rack system (G11, IVC and 829) using the image on a Gotek. I can issue DIR and receive the correct results. When I try and launch MBASIC I get a Drive Not Ready error. If I retry (or abort and re-issue the MBASIC command) it works and MBASIC works as expected. I will retry with the MFB 849 board in the same rack.
