Old 21st Jun 2018, 10:49 pm   #1
astro63
Default E.A.R record player model ?
Just bought first image pic battery player, thou listed as non working etc, cleaned battery terminals and hey presto works and has the original working acos HI-G crystal cartridge GP37 stylus. rubber wheel was solid so replaced with a BSR type and not even a crackle on the volume switch. It sounds lovely
Ive seen and owned before these E.A.R players but never seen the battery versions as image 1, The deck was used in E.M.I sonic & marconiphone electric players around 1958, so guessing mine is around 1959-59, as the speed selectors changed ( emi deck ) 1960 as in pics 2 onwards as used in the dansette diplomat, dynatron romany etc.
Theres a major design fault with pic 1 is that 10" / 12" you can put on the turntable unless you lift the pick up arm of the rest and hold it while you place the record on the turntable .
Any as you can see there is battery & electric versions BUT what is the model
ID:	165006   Click image for larger version
ID:	165007   Click image for larger version
ID:	165008   Click image for larger version
ID:	165009   Click image for larger version
astro63 is offline
Old 22nd Jun 2018, 7:02 am   #2
Edward Huggins
Default Re: E.A.R record player model ?
I think this was called the EAR "AutoBat". Glad you got yours to work OK, but just hope that isn't a Stereo LP you aare playing in the 2nd pic!
Edward.
Edward Huggins is offline
Old 22nd Jun 2018, 8:39 am   #3
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Back in the day I had the Battery operated model. Mine was Grey and had the deck with the large thumbwheel type speed change control. I don't remember the Model no., unfortunately.
'LIVEWIRE?' is offline
Old 22nd Jun 2018, 12:59 pm   #4
tracypaper
tracypaper's Avatar
It' not an AUTOBAT as the Autobat has an Automatic turntable hence the word Auto in Autobat and Bat meaning battery, yours has a manual deck and what it is called has just slipped my memory for the moment
I have just acquired an Autobat and will be submitting a post about it soon.
Gaz.
tracypaper is offline
Old 22nd Jun 2018, 1:42 pm   #5
'LIVEWIRE?'
I also used to own an Autobat in the 60s, plus it's add-on Stereo Amplifier. They used 6 x 'D' cells (or 'U2's as they were called then), with no provision for a mains adapter, though a socket to accept one could no doubt be added. The amplifier in the Autobat is probably the same as that fitted to the manual player in this thread.
Old 22nd Jun 2018, 3:05 pm   #6
AC/HL
AC/HL's Avatar
It may just be called "Portable": https://www.vintage-radio.net/forum/...ad.php?t=17391
AC/HL is offline
Old 22nd Jun 2018, 3:17 pm   #7
tracypaper
tracypaper's Avatar
I think it's called a Packagram and there was a version with a radio fitted as well simply called a radio-packagram.
Gaz.
Old 22nd Jun 2018, 3:18 pm   #8
astro63
Hi edward, i dont have stereo albums all lovely mono
ive owned the Autobat radio gram recently with the monarch deck that takes like 10 singles, then saw just the gram version shortly afterwards,
the gram version has 2 knobs compared to the radiogram version
am wondering if they are a follow on / update to the playbat 4 speed etc thou id like the one as seen in the advert
ID:	165056   Click image for larger version
ID:	165057   Click image for larger version
astro63 is offline
Old 22nd Jun 2018, 3:21 pm   #9
astro63
hi tracey the pakagram used the single play 2 speed staar decks , as used in the dansette classic and princess, this model i got is a mystery to what its called but wont give up yet
astro63 is offline
Old 22nd Jun 2018, 4:40 pm   #10
astro63
hear is the pakagram radiogram and gram ( pic 1-2,) pic 3 autobat radiogram? mark2 version.
pic 2 listed on radio museum as autobat which is incorrect
ID:	165062   Click image for larger version
ID:	165063   Click image for larger version
astro63 is offline
Old 22nd Jun 2018, 7:35 pm   #11
Edward Huggins
The two "Radiogram" versions shown above were actually made by Perdio after they had acquirred EAR. They both used an exisiting Perdio AM RF section ahead of a 4 transistor amplifier. To add to the interest, by this time Perdio were also building maind record players under the CIVIC brand name.
Edward.
Old 23rd Jun 2018, 10:38 am   #12
astro63
thanks for the information edward, didnt know it was perdio on the pakagrams
astro63 is offline
Old 23rd Jun 2018, 12:11 pm   #13
Edward Huggins
NB: Only the later (1962/63) versions with Radios built in.
Edward.
Old 23rd Jun 2018, 12:57 pm   #14
tracypaper
tracypaper's Avatar
OK, I can see the difference in the cabinet design as well, but when you type a google search for packagram it shows many differences in the images section.
By the way, It's Gary not Tracy.
Gaz.
Old 23rd Jun 2018, 10:36 pm   #15
astro63
Sorry Gaz for changing your sex ooops thanks for your info as well on the above player.
astro63 is offline
Old 25th Jun 2018, 9:13 am   #16
ben
ben's Avatar
'Manbat'?
I'll get me coat!
Ben.
ben is offline
Old 25th Jun 2018, 12:45 pm   #17
tracypaper
tracypaper's Avatar
swap it round...
Batman...
I'll get my coat as well
Old 25th Jun 2018, 11:01 pm   #18
astro63
I've gotta say for a battery player and original crystal cartridge no tone control it must be the best I've heard, got a lovely mellow tone, for £30 a bargain
ID:	165229   Click image for larger version
astro63 is offline
