Reply
Old 23rd May 2010, 10:41 am   #381
Top Cap
Top Cap's Avatar
Default Re: The "Sussex" Homebrew Valve Tester.
Hi Mike, re-checked both the Anode and Screen selector switches and all produce correct Gate input voltages. What is strange is that both MOSFET's behave the same in as much as the Source voltages change correctly from 300V down to 225V and then it holds at 220V for the rest of the lower settings. The BUZ80's I am using have an internal Zener (I bet it is 100V) for protection and I am wondering if the Zener conducts when the source drops below input on the Drain (320V) - 100V (Zener) = 220V. I may order some IRF820's but I want to check up on their spec's first. It still bugs me how both circuits are behaving the same even though they are separate from each over, the wiring appears to be correct but will keep looking. Any thoughts on the BUZ80's internal Zener? Could this be the culprit?
Les
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline   Reply With Quote
Old 23rd May 2010, 10:51 am   #382
Top Cap
Top Cap's Avatar
The IFR830 looks good at 60p each, has an internal diode for protection but it is a normal diode and not a Zener. It might be worth a try me thinks.
Les
Old 23rd May 2010, 12:02 pm   #383
swordholder
Les,
I didn't know about the zener in the BUZ80, mine were old (but brand new) so may be different.
It would be interesting to know what Neil used in post #342 used in his tester.
I don't think the type is critical as long as the ratings are OK
Regards
Mike
swordholder is offline   Reply With Quote
Old 23rd May 2010, 2:48 pm   #384
Top Cap
Top Cap's Avatar
Bearing in mind the limited voltage ranges available, I decided to try testing an EL34. The Gm was out of this world , I had set grid drive to 1V rms instead of 100mV. Now reset to the correct figure I duly set up grid voltage as per the AVO 160 Handbook and followed the switch coding as well. The quoted Anode current should be 75mA with that bias and furnish a Gm of 11. I was quite chuffed to get the results on the Sussex as per photo. The internal wiring could have been tidier but I am not a pro-wireman but no doubt it will tidy a little more later.
Les
Name:	valve under test_2.JPG
ID:	36191   Click image for larger version
Name:	front panel wiring pic.JPG
Old 23rd May 2010, 3:31 pm   #385
M0XNA Neil
Chaps,
I used the STP5NK80Z which is a To220 800V, 4.3A MOSFET which also has built in clamping zeners. They work fine.
Neil.
An engineer makes for a penny what a scientist makes for a pound!
M0XNA Neil is offline   Reply With Quote
Old 23rd May 2010, 4:08 pm   #386
Guitarist28
Guitarist28's Avatar
Gents,
Are we indicating that the BUZ80's are not suitable?
Regards
Rob
Guitarist28 is offline   Reply With Quote
Old 23rd May 2010, 9:15 pm   #387
swordholder
Rob,
I think the jury's out on that, as I use BUZ80's.
Let's wait and see what Les finds.
Mike
Old 23rd May 2010, 11:01 pm   #388
Andymic
Les,
Looks real tidy to me...
Andymic is offline   Reply With Quote
Old 25th May 2010, 7:53 am   #389
Bero
Hi all,
I am in process to finalize RAT tester, design by Steve Bench. Seems to me that's very similar to this design.
Things work, but I've stuck with LCD display, mine is only for DC voltage intended.
I've found in another thread on these forum schematics with TL072 and TL071 to convert this.
(https://www.vintage-radio.net/forum/...t=valve+tester)
I can't force them to read zero when input shorted, with no load he read about 400mV.
Can anyone suggest something, here is a schematic diagram, and picture presented what happen with signal across them?
Thanks in advance
Bero
Bero is offline   Reply With Quote
Old 25th May 2010, 8:49 am   #390
swordholder
Bero,
Not totally OK on op amps, but shouldn't the slider of the 10k pot go to -ve, it appears to go to ground on your diagram
Mike
Old 25th May 2010, 8:58 am   #391
ppppenguin
ppppenguin's Avatar
Mike is right. See page 8 of the TL081 data sheet:
http://focus.ti.com/lit/ds/symlink/tl081a.pdf
Also, what sort of LPF is that intended to be? It's not quite right for Sallen Key http://en.wikipedia.org/wiki/Sallen%...93Key_topology
ppppenguin is offline   Reply With Quote
Old 25th May 2010, 12:36 pm   #392
Bero
Jeffrey,
In original Steve Bench design, grid 1 of the tested valve is fed with a 1 kHz signal produced by 74HCO4 chip.
Monitoring that signal on anode side, you can read GM/MU of the tested valve using simple external AC millivoltmeter.
I think this arrangement (low pass filter) is because of two reasons,
first is to convert AC millivolt signal to be suitable for DC LCD 200 mV panel meter used here.
And second is to filtering anything else instead 1 kHz signal, to ensure better precision.
This is what I think looking at the arrangement.
But thing don't work properly with this LPF.
Probably something is wrong redrawn on that diagram.
As you can see on the oscilloscope photos above schematics diagram,
Input is 1kHz pure signal, after first amplifier signal is amplified,
until that point seems to look OK.
But I don't know is it OK what's happen after second and third amp?
Mike,
I will try to reconnect slider of the 10k pot to the –ve 12V.
What to do with the pin 4 of the TL071?
Should I leave them unconnected in that case?
Thanks
Bero
Old 25th May 2010, 12:53 pm   #393
julie_m
According to this data sheet, the "offset null" pot should be 100KΩ and the slider should be returned to -12V. Which is also where pin 4 (supply -) should be connected.
julie_m is offline   Reply With Quote
Old 25th May 2010, 12:59 pm   #394
ppppenguin
ppppenguin's Avatar
If you want to make a simple opamp filter look at the Sallen-Key reference I gave before. This is another useful guide: http://focus.ti.com/lit/an/sloa024b/sloa024b.pdf
Also an online SK filter design tool. I cannot guarantee this works but it allows you to design LPF, HPF and BPF with ease.
http://www.changpuak.ch/electronics/calc_08.html
Old 25th May 2010, 2:26 pm   #395
jimmc101
jimmc101's Avatar
It's a "Multiple Feedback Band Pass Filter".
For an on-line design tool see http://sim.okawa-denshi.jp/en/OPtazyuBakeisan.htm
Plugging in the values shown give a 1.038kHz centre frequency, a gain of 2.35 and a Q of 1.5
Jim
p.s. As has been said, the (100k) balance pot wiper should go to -ve supply, there is a slight chance the OP-AMP may have been damaged by the incorrect connection.
jimmc101 is offline   Reply With Quote
Old 25th May 2010, 2:52 pm   #396
jimmc101
jimmc101's Avatar
Oops, I forgot to address the original question.
The Waveforms look about right.
The second stage has a gain of 2.35 at 1kHz and so is being driven into clipping, reducing the input should restore a sinewave here.
The third stage is a precision rectifier, the voltage on pin 2 is forced to be the same as the input on pin 3 by the feedback through the diodes. The output at pin 6 should be equal to the signal plus a square wave equal to (the forward drop of the diodes plus the DC out).
The effect of this is that the (rectified) current through the 150R is equal the input signal at pin3 divided by Rx where Rx = (330R + resistance of 2k pot to earth).
e.g. If the 2k pot is shorted, then an average signal voltage of 330mV at pin 3 will produce 1mA DC through the 150R giving a reading of 150mV on the DPM.
Jim
Old 26th May 2010, 7:35 am   #397
Bero
Wow...
What a fast help.
And thing works, thanks to all.
Like you suggest, I've connect pot. slider to –ve12V. And now is LCD easy set to zero.
I was considered about pot value (10K in circuit, 100 K in datasheet) but seem that value isn't critical.
First I've try 22K, and 47K. There isn't significant difference on LCD display.
Thanks
Bero
Old 26th May 2010, 7:51 am   #398
Bero
One thing I've forgot to mention.
Neither in Steve Bench schematics isn't said,
that DMM must be connected via blocking cap to get proper readings, even if you use a DMM.
After all this time spending to get LCD readings,
when thing sprang to life (thanks to your advices), I've connect them to output points onto PCB.
Seems to both chips are burned now ... there was about 250V on the anode.
Old 26th May 2010, 8:07 am   #399
Bero
And here you can see progress...
There isn't finished yet, this is roughcast point, but nice to know that thing works.
Regards
Bero
ID:	36326   Click image for larger version
ID:	36327   Click image for larger version
Old 26th May 2010, 10:19 am   #400
Bero
Jim
According to your calculation, I've think about 2K pot value.
If I need reading 200mV across 150R resistor, 200 divided by 150 gives 1.33mA current via 150R resistor.
With 200mV signal at pin 3, divided by 1.33mA current, calculated value of Rx need to be 150R.
But on diagram is Rx =330R+resistance of 2K pot to earth.
Even with 2K pot set to the zero, Rx would be 330R, and this is more than twice of calculated value for Rx.
Is this another wrong redrawn in circuit or calculation mismatch?
Reply
