4th Aug 2008, 7:53 pm | #1 |
Isolated lamp limiter supply
Hi All,
I don't know whether this is worth sharing, but I've made an isolated supply for testing mains driven appliances such as radios, TV's etc with a bit of a twist. I can draw up if you really need to, but here are the basics: I have a 3amp 240>12V transformer connected to the mains and then another nearly identical transformer wired to the output to raise the 12VAC back to 240VAC at a limited current and isolated from the main supply. To give me an indication if I'm running near to the limit of the 12V windings, or if there's a fault, I have a large (about 150W) 12v bulb wired in series with the 12v windings so the power runs through the bulb. The result, if I connect a black and white TV with load of about 30W to the output of the second transformer it works fine and gets about 220v. The 150w bulb glows dimly. If I short the output, the bulb glows brightly and no harm is done. I've tied one side of the output to an earth strap also to give a realistic output supply too. I hope this all makes sense and is of use, or you have any comments. I can draw up if you want. All the best, Trevor
I'd just like to say "Good luck, we're all counting on you" |
4th Aug 2008, 8:05 pm | #2 | |
Re: Isolated lamp limiter supply
Using a pair of transformers like this is a perfectly good way to improvise an isolating transformer when none is available. |
4th Aug 2008, 8:14 pm | #3 | |
I would have thought that connecting one side of the output of the second transformer to the Earth of the mains supply should not compromise isolation from the current carrying side of the mains as the 240V at the output has no direct connection to the mains supply. Assuming of course that your mains supply is safe.
4th Aug 2008, 8:19 pm | #4 | |
With one side of the output connected to mains earth measure the voltage from the other side of the output to mains earth, a radiator or a cold water pipe. Repeat with the output disconnected from earth.
4th Aug 2008, 8:20 pm | #5 | |
One side of the mains (neutral) is at approximately earth potential and is safe to touch. The other side (live) isn't. One side of the output of your arrangment is at earth potential and is safe to touch. The other side isn't. In either case if you manage to touch the live side and earth at the same time a harmful current will flow through you. PS: StationX got there before me. He's quite correct except that if you do the measurement with a high impedance meter you will get spuriously high voltages due to capacitative coupling. Suggest using a low wattage mains light bulb for the test. |
4th Aug 2008, 8:36 pm | #6 |
Ok, I stand corrected. I will remove the earth strap.
4th Aug 2008, 8:39 pm | #7 |
Hi Trevor,
That's a clever way of doing things. But the others are right about the wisdom of tying one side of the OP to earth. The other downside with your current arrangement is that if you touch the non-earthed output terminal, not only could you get a nasty shock, but any RCD that you may have in your consumer unit wouldn't trip either - so more dodgy than using "raw" mains directly from a 13A socket So cut that earth connection, then enjoy your useful gadget. Nick. |
4th Aug 2008, 8:46 pm | #8 |
Thanks Nick. I've done it as we speak. I must admit I have found it quite useful.
