Old 16th Feb 2019, 8:59 pm   #1
G6Tanuki
G6Tanuki's Avatar
Default Extruded sectional cases.
A few decades back I used equipment-cases that were made from ribbed aluminium extrusions that slotted together end-to-end - we always called them "Hide cases". They were ribbed on the outside and had internal guides to take standard-sized PCBs/veroboard etc.
They were great because the aluminium was thick enough to let you taper-mill a screwhole from the outside and still have enough thickness to reliably mount a TO220-style transistor or one of the ubiquitous 7805/7812/7815/7824 voltage-regulator so using the case as the heatsink to dissipate a few Watts.
There seem to be various obscure design-clones available from Alibaba etc, but are any of them any good?
G6Tanuki is offline
Old 17th Feb 2019, 12:46 am   #2
Argus25
No Longer a Member
Default Re: Extruded sectional cases.
Over the years, for nearly all my projects I use Extruded aluminium Takachi cases. They are 3mm thick extrusions , but the genius of them is the extrusion is from side to side and the are folded around the width, so the extrusion slots retain the front and rear panels. You can also buy chassis inserts etc for them. They come in a lovely dark green -grey color anodized they call bronze, or a white/cream coated version:
These are the UC series enclosures:
http://www.takachi-enclosure.com/data/c16-17/UC.pdf
Also they do the heatsink style enclosures like these, effectively extrusions with end caps and many more types, visit their website:
http://www.takachi-enclosure.com/data/c16-17/HEN.pdf
You can get them directly from factory sales and they send them via Japan Post and their enclosures are great value.
I've attached a couple of photos of things in Takachi cases, one radio transmitter (with the top off) and a dual disk drive unit I recently made. Another is a surgical instrument I made, built into their enclosure.
Takachi make the best quality instrument cases on the planet currently (in my opinion). They also have numerous accessories, feet handles and very many case types.They also will machine panels and make custom cases. They have the excellent finish and precision and attention to detail that is typical of quality Japanese Engineering & culture.
ID:	178535   Click image for larger version
ID:	178536   Click image for larger version
Argus25 is offline
Old 17th Feb 2019, 8:54 pm   #3
buggies
buggies's Avatar
Were they Hyde? West Hyde Enclosures Ltd.
Taken over by Hammond about 12 years ago.
Some here:-http://www.hammondmfg.com/sinkbox.htm
Haven't checked if sold in UK.
George
buggies is offline
Old 17th Feb 2019, 9:37 pm   #4
MrBungle
MrBungle's Avatar
Another vote for Takachi. Everything I build goes in one of their boxes. Also to note, RS sell them.
MrBungle is offline
Old 17th Feb 2019, 10:02 pm   #5
G6Tanuki
G6Tanuki's Avatar
Brilliant!! That's the ones! ! I know that there are a couple of Hammond disties in the UK (including RS) but not sure if they carry the full Hammond range. Time for some investigations I think...
G6Tanuki is offline
