Old 23rd May 2019, 12:20 pm   #1
LyntonP
LyntonP's Avatar
Default Unknown radio. Identified as a Murphy A34.
I have been offered this radio from an old school friend. No idea what it is and haven’t seen it first hand yet. Anyone know what it might be?
Lynton
Never buy a mermaid a pair of socks!
LyntonP is offline
Old 23rd May 2019, 12:24 pm   #2
ms660
ms660's Avatar
Default Re: Unknown radio
Murphy A34:
https://www.radiomuseum.org/r/murphy_a34_a_34.html
Or D34:
https://www.radiomuseum.org/r/murphy_d34.html
Lawrence.
ms660 is offline
Old 23rd May 2019, 12:38 pm   #3
LyntonP
LyntonP's Avatar
Thanks Lawrence. I did have a quick look on the radio museum site but couldn’t find anything.
Lynton
LyntonP is offline
Old 23rd May 2019, 12:52 pm   #4
Nanozeugma
Nanozeugma's Avatar
Location: London, UK. Bury, Lancashire quite regularly :)
It is indeed a Murphy A34. There is currently an example of the AC/DC variant (D34) on offer on eBay.
https://www.ebay.co.uk/itm/Vintage-M...UAAOSw2-pc2Cwj
Thermionic Emission, warms the cockles of your tubes.
Nanozeugma is offline
Old 23rd May 2019, 1:02 pm   #5
dave walsh
There are threads on here via a search Lynton, including one set that's "motor boating" ie oscillating. Google "Diagram Dungeon" for a great Murphy site. Click on the model number for an illustration of your set and the Radiogram version. The table top was £17 in 1932 it says, reduced to £13 by November!
I wonder why?
Dave W
dave walsh is offline
Old 23rd May 2019, 1:36 pm   #6
radioman
radioman's Avatar
Default Re: Unknown radio. Identified as a Murphy A34.
The A34 was from 1937 - I think it's the A3A from 1932 that you're referring to Dave !
Regards,
Andy
G-QRP #12697
radioman is offline
Old 23rd May 2019, 2:57 pm   #7
dave walsh
Oh yes, quite right Andy 1937 I was looking at the correct sets but the wrong info. I'll blame it on a Windows 10 unstable scroll up or Spec "Saviours" Price correction the table top was £10-10/- in 1937. I might have clocked the date mistake but the A34 looks a bit basic for 1937. Maybe it was built down to a price
Dave
Old 23rd May 2019, 3:00 pm   #8
ms660
ms660's Avatar
According to the schematic it has an inter-station noise suppression feature.
Lawrence.
ms660 is offline
Old 23rd May 2019, 3:12 pm   #9
dave walsh
Oh really Lawrence. I suppose that and the magic eye takes it up scale a bit
I've got the same feature on my [unrestored] Marconiphone 296 RG. It seems to be an electro-mechanical system and it is specifically mentioned in the original Instruction Book that came with it.
I recall that an electronic "no hiss between stations" feature was promoted in some solid state Tuners during the 70's. When I got the Radiogram in the mid eighties, I very was surprised to see that "silent tune" was a feature back in 1935! Nothing new under the sun eh?
Dave W
Old 23rd May 2019, 3:52 pm   #10
ms660
ms660's Avatar
For inter-station noise suppression, the A34 uses the cathode & g3 of the IF amplifier as a diode which is connected by way of, what are in effect (for explanation purposes) two resistances to the cathode of the detector diode, the two resistances form a potential divider to which the anode of the detector is connected, the cathode voltage of the IF amplifier is lower than that of the detector's cathode, that therefore makes the detectors anode voltage lower than the voltage on its cathode, the voltage difference being the threshold voltage for detection.
I've never owned or used one of these receivers so I've no idea how effective it is in reality.
Lawrence.
ms660 is offline
Old 23rd May 2019, 6:28 pm   #11
LyntonP
LyntonP's Avatar
The set has been delivered and it is indeed the MW/LW variant with the interference suppression operated by a switch on the rear. A very quick inspection shows that the cabinet is not too bad, would need refinishing, but even before removing the chassis it is obvious that it will need a complete rewiring job done. All the exposed insulation on the cables is crumbling to dust. The tuning scale doesn’t seem to work, and the set is very mucky inside (only to be expected really). I have printed the service manual - very extensive! And the valve complement are numbers that I have never heard about! It was made in 1937 and as mentioned the original price was around £11.00. The valves are listed as Mazda AC/TP, AC/VP2, AC/PenDD, UU4, and AC/ME. Are such items still available?? An unusual feature is that the loudspeaker is housed in a draw string bag! Never seen that before.
Is it worth progressing with me being a novice, or is this more for an experienced person?
Lynton
LyntonP is offline
Old 23rd May 2019, 6:40 pm   #12
HamishBoxer
HamishBoxer's Avatar
You could possibly sort it with guidance BUT Do Not Plug in till certain bits are changed/checked.
Though,if in doubt then let some one else do it.
Yes,I have had a few speakers in drawstring bags,keeps the dust out!
HamishBoxer is offline
Old 23rd May 2019, 7:01 pm   #13
ColinB
ColinB's Avatar
If you like the set and want to get it working, then go for it. Post a thread on here and you should get plenty of help and encouragement.
Be sure to work safely however, bear in mind that this is a mains powered device, and it needs to be treated with respect... For an intro to repair and restoration, have a read of this site...
https://www.vintage-radio.com/repair...ion/index.html
ColinB is offline
Old 23rd May 2019, 7:39 pm   #14
PJL
Best to check the continuity of the output transformer primary, mains transformer primary and HT secondary, and the speaker field coil before you start.
PJL is offline
Old 23rd May 2019, 7:50 pm   #15
LyntonP
LyntonP's Avatar
I have been watching a series on you tube called Electronics old and new by Marc Calderia. He does the same as you suggest and more checking many things before applying power. He also shows how to construct items which are useful when doing restorations. He favours German sets but will tackle almost anything? Very clever chap whose background is in the electronics field. Worth a watch, and he does respond to comments.
Lynton
LyntonP is offline
Old 24th May 2019, 2:29 pm   #16
LyntonP
LyntonP's Avatar
Lawrence.
Lawrence do you have any idea where I might find more information about this system? Been looking on the net with no luck.
Spent some time cleaning the chassis and cabinet.
Most of the valves have no ID numbers other than the magic eye, and there seems to be an extra valve connected to V1 which is not mentioned in the service data. Looks like an add on with a modified valve holder (see pic).
The extra valve holder was screwed to the side of the cabinet.
Any ideas?
Lynton
ID:	183743   Click image for larger version
ID:	183744   Click image for larger version
ID:	183745   Click image for larger version
LyntonP is offline
Old 24th May 2019, 2:56 pm   #17
HamishBoxer
The valve holder that was screwed on to the cabinet has been done to use a substitute.
Getting the correct valve line up is no problem.
I notice you already have the valve types and that is looking left to right,excluding the magic eye.
Old 24th May 2019, 3:08 pm   #18
crackle
Were there valves in all of the 4 valve holders on the chassis (not including the magic eye mounted by the dial) as well as a valve in the additional valve socket fitted sideways?
I am trying to work out if the additional socket is to replace the original one because the only replacement valve they could find was a 5 pin one not the original 7 pin one.
Mike
Hamish posted whilst I was typing.
crackle is offline
Old 24th May 2019, 3:22 pm   #19
LyntonP
LyntonP's Avatar
The extra valve holder on the cabinet has a AC/HL valve fitted, and V1 in my radio is a V4HP. So are these two valves used instead of the original AC/TP which is listed in the service manual? If I had the correct V1 could the ‘adaptor’ which is shown in the photo be removed?
Also V3 which should be a AC/PenDD has a loose top connection (on top of the glass envelope).
Lynton
LyntonP is offline
Old 24th May 2019, 3:28 pm   #20
HamishBoxer
It could be a case of using 2 valves instead of one, I would try for the correct one. I think you have picked a messy set to start off with as a first, due to unofficial mods.
Re loose top cap, carefully put a bit of Super or similar around to secure.
Also, the magic eye is most likely u/s.
