Old 2nd May 2019, 1:37 pm   #21
Tractorfan
Tractorfan's Avatar
Smile Re: Philips Reel to Reel help!!
I found, after a mention on the forum, that brake fluid works pretty well to get the worst of it off, followed by meths to remove the brake fluid residue.
Cheers, Pete.
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 6th May 2019, 11:51 pm   #22
ben
ben's Avatar
Default Re: Philips Reel to Reel help!!
Don't forget a supply of wooden toothpicks. These are essential to remove the last of the goo from the deepest crevice of the pulleys, unless this is done thoroughly the goo remaining will contaminate the new belts.
Somewhere I have the dimensions of the main belt, an o-ring as used in hydraulic systems works well. VCR rubber tyres work well on the pulleys. Do not forget the brakes, the pause stub and the clutch inserts on the spool tables.
Regards,
Ben.
ben is online now
Old 7th May 2019, 9:22 am   #23
placemat
Thanks Ben.
placemat is offline
Old 30th Aug 2019, 10:12 pm   #24
hillmanie
Originally Posted by unitelex View Post
I was de-gooing a Philips N4407 last week.
I tried IPA Isopropyl Alcohol and Methylated spirits, the latter was better
As others have said the Goo gets everywhere, hands, tools, anything you touch after working on it, light switches, doors...
Best not to start by trying to wipe the stuff off, it just spreads.
I would recommend scraping the stuff off with a screwdriver or spatula first, then wiping whats left with solvent doused tissue. Then dispose of the tissue and start again with a new one...
Old thread but very immediate for anyone acquiring an old Philips reel to reel. All that has been said about the Goo is true and more. The stuff is incredibly deadly and as stated if it gets on your hands - well - trouble. The stuff has the tenacity of ink.
I've got it in the N4306 of recent days. It's probably not as bad as might be as the belt melted down on the deck in its own trace. I don't yet about the clutches as I haven't taken off the reel hubs. Difficult? I'll do as advised, careful scrape first and then the solvent. Fortunately there's a guy in Italy selling the kit within my budget
TT
hillmanie is offline
Old 31st Aug 2019, 7:37 am   #25
wd40addict
wd40addict's Avatar
In my Cossor CR1601 (Philips EL3542) the goo was also slightly conductive! This led to two weeks of obscure amplifier fault tracing because some had found its way into the record switch, bridging unrelated contacts in a very high impedance point in the amplifier. The cure was removing the sliding contact PCB and cleaning the residue off with meths.
This machine is normally considered from before Philip's gooey phase, but I wonder if a replacement belt was fitted back in the day made from the newer material.
wd40addict is offline
Old 31st Aug 2019, 9:22 am   #26
hillmanie
Something else to be on guard for. Horrible horrible stuff. Re scraping I'll also try a sharp edge like a Stanley knife blade. As It'll be scraping mostly the metal deck - should be no danger. Yes, I'd noticed it melted into pulley grooves and figured these would need special treatment.
TT
