15th Nov 2018, 10:48 pm | #1 |
DC motor speed control
I am trying to fix a potters wheel for a friend. Basically, it runs, but at the slow setting it still runs too fast.
The motor has EMD marked on it and has brushes / commutator. So I suppose it runs on DC? There is also a tacho. The control pcb has mains to it, and has I think, two 2N3525 SCR's but no makers name/ part number to identify it. The speed control is by a 5k pot mechanically linked to a foot pedal. The pot track / wiper checks out ok. I attach some pictures in the hope someone may recognise the kit and perhaps provide a circuit to enable diagnosis? Any help most appreciated.... |
15th Nov 2018, 10:51 pm | #2 |
Re: DC motor speed control
Could be a universal motor. Nothing unusual. Most washing machines have motors with brushes running on AC controlled by a tacho.
15th Nov 2018, 11:00 pm | #3 |
I'm not too hot on motors....
Apart from the tacho (2 wires) it has 4 wires to from the controller. Is that any sort of clue? |
15th Nov 2018, 11:26 pm | #4 |
EMD is Electric Motor Developments, no longer trading. Several potters wheels here in Staffordshire used them, though I've never seen one like that before with a tacho. All the ones I've fixed (and I've fixed very many!) had dc shunt motors on them, no tacho. A universal motor of course is not so easily reversed!
Kevin |
15th Nov 2018, 11:48 pm | #5 |
Well, this setup has a DPST switch connected to the controller which reverses the motor. So does that suggest its a DC motor?
Also what sort of speed would be acceptable on slow setting? Last edited by squegging; 15th Nov 2018 at 11:49 pm. Reason: extra question added about speed |
16th Nov 2018, 12:18 am | #6 | |
I'd have guessed all the way to standstill with the pedal backed off.
Kevin |
16th Nov 2018, 1:56 am | #7 |
universal motors reverse if you reverse the connactions to either the brushes, or to the field (just not if you do both!)
4 wires from the motor to the controller would allow this. David
16th Nov 2018, 10:56 am | #8 |
I have just measured 110vdc (slow) to 220vdc (fast) across the brushes, and 17vdc (slow) to 18vdc (fast) across the field.
When the direction switch is operated, the field changes polarity. So now to start tracing out the circuit.... could be a while. Watch this space! |
16th Nov 2018, 12:59 pm | #9 |
Two pots on the control board, min and max speed?
16th Nov 2018, 3:16 pm | #10 |
The photo of the pcb, top left, shows a transformer that looks like it is designed for 50 Hz operation. Just above it, I think I can see 4 diodes. Also, there a few electrolytic caps. in that region too. To me, all that suggests that the controller - and thus the motor - is operated from d.c.
With that in mind, merlinmaxwell's above comment seems possibly relevant. Al. |
16th Nov 2018, 5:29 pm | #11 |
Is this motor directly coupled to the wheel, or through a belt/ gearbox system?
If that is the case and you do not need the max speed, alter the drive ratio. Ed |
16th Nov 2018, 5:51 pm | #12 |
Hello.
Before delving in too deep, try removing the 1/4 watt resistor from the choc block connectors. I agree with Merlin, the two presets are for minimum and maximum speed settings. It could be that someone has ‘ modified ‘ the unit by fitting this extra resistor. Good luck!! SimonT.
The honesty of imperfection.......... |
16th Nov 2018, 6:14 pm | #13 |
Two pots on the board, both set at the end of their travel. Suspicious?
16th Nov 2018, 7:27 pm | #14 |
The resistor fitted in the terminal block could just be a pull down resistor just in case speed control input goes open circuit.
16th Nov 2018, 8:34 pm | #15 |
Check that the tacho magnet is properly secured, we have found many that are loose so the tach doesn't get up to speed.
17th Nov 2018, 11:44 am | #16 | |
There is belt dive reduction using two "fan belts". Smaller pulleys x2 64mm running dia, larger ones x2 241mm running dia. So I reckon overall the ratio is 14.18:1. So plenty of torque on the turntable. Not so easy changing gear! And thanks everyone else for your interest and suggestions. There are indeed two pots L & H which I haven't yet touched, but will give them a good twiddle to ensure their wipers are ok when I can get back to the job. Last edited by squegging; 17th Nov 2018 at 11:50 am. Reason: correction |
17th Nov 2018, 11:48 am | #17 |
20th Nov 2018, 11:49 am | #18 |
Merlinmaxwell hit the nail on the head. When I originally got the job, there was no speed control at all. The wiper of the main speed control pot linked to the foot pedal was not making contact. After cleaning it up, there was some reduction in speed, but not enough.
Tweaking the two pots on the pcb meant that I could now bring the motor to a standstill. Problem solved. |
20th Nov 2018, 3:26 pm | #19 |
Thank you, I am glad it worked!
