17th Sep 2019, 2:04 pm | #1 |
Heathkit Stereo Tape Recorder STR-1
Hi!
I've started Scanning of the Full Assembly Manual & the files'll be posted here as soon as the various sections are ready to post! Chris Williams
17th Sep 2019, 4:34 pm | #2 |
Re: Heathkit Stereo Tape Recorder STR-1
Hi!
Manual Covers. . . Chris Williams
17th Sep 2019, 5:01 pm | #3 |
Can I just say in advance, thanks for doing the scanning. It will be great to have the circuits etc for when I restore mine.... in the distant future!
Cheers, Peter |
17th Sep 2019, 5:02 pm | #4 |
Looking forward to seeing the rest of this.
Well done Chris! Graham
Half my stuff is junk - trouble is, I don't know which half! |
18th Sep 2019, 11:09 am | #5 |
Hi!
Introduction, parts list & soldering guide. . . Chris Williams PS! Keep watching this space, more coming!
18th Sep 2019, 1:38 pm | #6 |
Hi!
PCB Assembly steps. . . Chris Williams
18th Sep 2019, 2:42 pm | #7 |
PS!
I'll scan the larger Pictorial Sheets at the end when I've done the basic pages! Unusually, Heathkit don't appear to have issued any large sheet fold-out pictorials for this kit as none are referred to in the Manual instructions, but I'll make sure everything gets scanned & uploaded! Chris Williams
19th Sep 2019, 11:05 am | #8 |
Hi!
Block Diagram, Circuit Diagram, Layouts, Voltages and Fault-Finding Tables. . . Please let me know if anything's difficult to read and I'll re-scan if needed! Chris Williams
19th Sep 2019, 1:20 pm | #9 |
Hi!
Press-Button Switch Wiring and Initial Chassis Assembly. . . Chris Williams
19th Sep 2019, 4:06 pm | #10 |
Hi!
Final Chassis Assembly/Wiring & Initial Tests. . . NB! A tiny corner of the Chassis Pictorial has overlapped onto P. 30 which means the Full Pictorial will have these tiny corners missing, but anyone who's good with Technical Drawing should be able to draw the missing corners in! Chris Williams
20th Sep 2019, 1:30 pm | #11 |
Hi!
Testing & Setting up with instruments. . . Chris Williams
21st Sep 2019, 7:25 am | #12 |
Hi!
High Resolution 600 DPI Copies of Circuit & PCB Layout Diagrams for anyone who needs the best ones. . . Chris Williams
21st Sep 2019, 8:23 am | #13 |
Thanks for doing this Chris!
I don't own the STR-1, but as a long term Heathkit collector it's interesting to study its design. I wonder if the electronics were a purely British design or whether it's an adaption of something from the US. |
21st Sep 2019, 12:50 pm | #14 |
Hi!
I think the design is (very roughly!) based on the Mullard 3W Tape Amplifier with extra refinements added by Heathkit for three–speed playback compensation. Another major difference was that the Mullard circuits used the erase–head itself as the bias–oscillator coil, in a Colpitts type circuit, which necessitated a relatively low impedance R/P head, as the bias voltage from across the bias oscillator circuit isn't adequate for the normal type of head without using an additional step–up transformer! If you wish to study the Mullard Circuits, download the January and February 1971 issues of "Practical Wireless" from the American Radio History site and look at the "PW Stereo Tape Recorder" project! There's still more Heathkit Manual & the larger pictorials from it to come, by the way! Chris Williams
21st Sep 2019, 9:02 pm | #15 |
The very British TD10 deck would make this seem like a purely British design (and even more so considering the relationship to the Mullard 3W amp design) so possibly it was never sold in the USA at all?
21st Sep 2019, 9:14 pm | #16 |
Hi!
The Assembly Manual itself gives the uniquely British design of this machine away in itself, as apart from the manual text, whose typeface I'm still trying to find the name of (it's NOT any form of Courier!), the drawing lettering itself is entirely British in design as well – in fact all five of the different styles of British Drawing Lettering are mixed up in the circuit–diagram here and there! There were American Heathkit R to R machines made, and I believe it was possible to get some of the kits specially imported (at great expense!) at one time, the decks were entirely an American product and the amplifier totally different in design! Chris Williams
21st Sep 2019, 10:03 pm | #17 |
Thanks for this information Chris , Very useful.
Will study it in detail when and if I get a chance.. Only other Heathkit bit of kit I have is a Short wave receiver... Peter W Reelguy. |
23rd Sep 2019, 11:50 pm | #18 |
Hi!
On a more technical note than the Assembly Manual, the STR–1 I bought has two faults, one mechanical and one electronic! The mechanical one is I can't move the joystick into rewind and fast–forward is very sluggish, so I bit the bullet and bought the exploded view manual so I could investigate it, the most likely cause being ancient goo, so it looks like printing out all the diagrams and do a bit of James May on it! The electronics fault is very, very low volume from the L.H. channel on both replay & record, with no indication on the record–level meter – I found the record monitoring volume virtually the same as the playback volume, so that and the non–responding meter almost certainly points to an o/c electrolytic in the first three L.H. channel stages! (Of course there could be an o/p amplifier failure, but as this is only three transistors with a silicon transistor driver, chances are that will be working! On a design note, Heathkit used a 6000μ 40V reservoir/smoothing capacitor, much more than the 2000–3500μ that was the usual value in most transistorised mains–powered amplifiers of that era – I don't think the Wharfedale amp my friend bought (a piano–key switch version of the Leak Delta 30) uses any more than 3300μ! Chris Williams PS! I'm not sure whose heads it's got, but I'll be using one of those little Chinese LCR testers if I have to check them as they use a.c. energisation of the test component, but quite honestly I'm not suspecting head failure!
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 23rd Sep 2019 at 11:59 pm. |
