Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay). |
20th Jul 2008, 10:29 pm | #1 |
Tubular dial lamp for HMV sets
Hi all,
Just found this supplier of lamps and they have a stock of lamps to fit the HMV sets that use this odd mains tubular lamp. It is a slightly higher wattage but my guess is it will be fine or alter the bulb tapping on the transformer? Either way it saves a lot of modification of other types of lamp and looks just like the real thing http://www.lampspecs.co.uk/Light-Bul...-100mm?whence= |
22nd Jul 2008, 7:00 pm | #2 |
Re: Tubular dial lamp for HMV sets
Thought folks would like to see the lamp in place. Paul. |
24th Jul 2008, 9:05 pm | #3 | |
Good lamp supplier, though, with a wide range of odd types. Thanks for posting!
24th Jul 2008, 10:10 pm | #4 |
Yes I agree having had time to experiment I have fitted a 1KΩ 10 watt resistor in series and that seems to be about right. It is certainly simpler to fit a resistor than trying to change lamp bases etc The lamp looks just the job Paul. |
30th Aug 2008, 6:49 pm | #5 |
You should have gone for these ones. Only a little shorter. http://www.lampspecs.co.uk/Light-Bul...4Pa38Ta38Mch10
The 55W looks like a missprint. Last edited by humphrey; 30th Aug 2008 at 7:17 pm. |
30th Aug 2008, 8:14 pm | #6 |
Already tried one of these and unfortunately they have a "coiled", filament which only gives a spot of light. The tubular lamp I am using has a single festoon filament running along the tube. Thanks anyway, Paul. |
30th Aug 2008, 8:28 pm | #7 |
Au contraire, I was just about to order them. Thanks.
25th Sep 2008, 4:16 pm | #8 |
After looking at the crazy prices wanted for shipping, I got a microwave lamp rated at 15W and a socket with a rubber expanding collar intended for a table lamp. The whole dial is illuminated with no heat concerns.
25th Sep 2008, 5:13 pm | #9 |
I shall have to have a look at one in my local DIY shop. The ones I saw when looking the last time all appeared to have filaments that were to short or circular in construction. Paul. |
