Old 11th Jul 2018, 10:43 am   #21
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Strange event in my workshop?
With 100 Ohms, I don't suppose a megger will develop enough voltage to do anything.
I was going to suggest unplugging things to see what might clear it, but that's already been covered.
Radio Wrangler is offline
Old 11th Jul 2018, 12:09 pm   #22
Graham G3ZVT
Graham G3ZVT's Avatar
I once had a mystery low resistance reading between live and earth on one of my house wiring circuits, which tripped the RCD whenever the MCB for that circuit was closed.
I was surprised when I eventually tracked down the fault. A chain of carbonised ants forming a U-link between two terminals of my central heating wiring centre.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 11th Jul 2018, 12:44 pm   #23
The Philpott
The Philpott's Avatar
That doesn't surprise me! 'Bugs live in plugs' for some reason. The number of times i have found small spiders living (happily) in junction boxes... possibly because larger spiders can't get in and duff them up.
A pipe finder/power finder might be helpful to Paul. Less so if the shelf brackets are metallic.
The Philpott is offline
Old 11th Jul 2018, 12:55 pm   #24
HamishBoxer
HamishBoxer's Avatar
We all wait with interest as to the reason at the end of the day.
HamishBoxer is offline
Old 11th Jul 2018, 1:13 pm   #25
Skywave
Originally Posted by Station X View Post
Surely the resistance of 10 foot of wire is negligible and the 100 ohm earth fault could be at any point on the wire?
Yes, agreed. I was thinking too hard about this.
Al.
Skywave is offline
Old 11th Jul 2018, 1:58 pm   #26
kalee99
Hi all,
Yes the resistance of the wire from end to was less than 1Ω so good continuity. but measuring from either end to the mains Earth it was almost exactly 100Ω No mains voltage detected on the wire and running my 500 volt megger still gave a steady 100Ω. Some of the stuff on the shelves has not been moved for years but non of it is in anyway plugged into the mains or anything else. As the shelves are not moving any time soon it will just have to go down as one of life's great mysteries.
Paul.
kalee99 is offline
Old 11th Jul 2018, 2:14 pm   #27
Station X
Station X's Avatar
Originally Posted by kalee99 View Post
The 10 ft. bit of wire to my workbench that just runs along the wall behind my wooden shelving was the guilty party with 100Ω to earth on either end.
It’s just a bit of insulated wire...……... Paul.
Is the wire fixed to anything by staples or W.H.Y or does it dangle freely?
Graham. Forum Moderator
Station X is offline
Old 11th Jul 2018, 2:16 pm   #28
ms660
ms660's Avatar
I wonder if it was Tee'd off years ago and long forgotten?
Lawrence.
ms660 is offline
