29th Aug 2010, 10:28 pm | #81 |
Location: Near Lichfield, Staffordshire, UK, most of the time and Crystal Palace, S London, some of the time..
Re: Award for the worst plug design goes to...
AJS, afraid not, Loughborough, Towers hall late 70's. Seems they were trying to burn down numerous universities during this period....!
73 |
29th Aug 2010, 11:49 pm | #82 |
We had both 5A and 2A sockets in the hall I was in at Bangor in the 70s. The standard solution was to have a board with one or more 13A sockets connected to a 5A plug. This was usually good enough to run a kettle from. The hall, built in the 40s, had no ring main but groups of 3 rooms were connected to a single fuse. If for any reason the fuse blew an alternative "adaptor " was used, identical to the first but with a 2A plug.
I believe the hall was rewired during a major refurbishment and 13A sockets were fitted. Keith |
30th Aug 2010, 8:19 am | #83 |
Students never change eh? 2A sounds about right, I'm sure there was a brand name tho..
30th Aug 2010, 3:54 pm | #84 |
When I was at college, it was 2 single sockets or 1 double on a 20A radial 2.5mm or 6 singles (3 doubles) on a 30A radial 4mm, a 30A ring could have unlimited sockets and unlimited spurs provided the total number of spurs did not exceed the number of ring sockets, it did'nt serve more than 100msq, not including a kitchen which should have its own ring.....has it changed since? I'm talking 15th edition!!
I know 30A is now 32 in euro speak.
Kevin |
30th Aug 2010, 6:56 pm | #85 |
It was the University Estates dept that stipulated 2A per room, nothing to do with "the regs". This allowed a diversity factor of one, with 28 rooms per level split into 4 x 16A circuits, 6 floors total fed from a 125A 3ph incomer. I guess in the late sixties when the block was built 2A was deemed adequate (little chance of an iron or hoover being plugged in ).
Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
30th Aug 2010, 7:21 pm | #86 | |
@ McMurdo,
Hi, yes still pretty much the same, See :http://www.theiet.org/publishing/wir...8.cfm?type=pdf see last two pages of the pdf. (I wasn't sure if I could post the Pdf on here, as it will be subject to copyright from the IET) this shows exactly what you are allowed to connect and how, it is worth downloading the last two pages for your own references. Cheers, Baz
I don't suffer from Insanity. I enjoy every minute of it. |
28th Sep 2010, 10:25 pm | #87 |
The flat, 2-pin 5-amp Bulgin plug (the male version of the DAC90A connector) was pretty nasty, with no proper cord grip.
Then there is the Plessey military type that can be assembled with the pins in any configuration to suit the equipment being powered. I once used a mains lead from one instrument to power up a different instrument, and only after it didn't work did I check the mains wiring, to find that live wire now went to the chassis but amazingly, I felt nothing, not even a tingle. I was standing on carpet wearing rubber-soled shoes. I recall a safety recall notice from one manufacturer who put out a batch of 3-pin plugs that had a tendency for the top to come off as the user attempted to remove the plug from the socket, leaving the potentially live brassware exposed!
8th Oct 2010, 10:29 am | #88 | ||
Once again I'm a little late in to this one...!
As for wiring, new domestic wiring is all 20A MCBs feeding a number of socket outlets - not sure how many, most of ours feed about six double outlets. Outlets are just daisy chained. The whole lot has to be RCD protected. Outlets are ok in bathrooms as long as they are not too close (either 300mm or 500mm) away from wet areas. Lighting is protected by 10A MCBs (in our case staggered between rooms, so two adjacent rooms don't lose lighting at the same time if one trips). Hot water heating (3kW) is on its own 20A MCB. Oven on its own as well - the cooktop is on LPG so just plugs in to a normal socket under the bench for the ignition. |
9th Oct 2010, 9:14 pm | #89 |
I've got a Clix 13amp stackable plug and an NZ one I found at a UK flea market as well as a "Sturdee" NZ standard plug. That came in handy to make up an adapter to a 13amp trailing socket for our mobile phone charger on an anniversary holiday trip to Australia. Pity I took the wrong charger, Doh! . We now have an Australian phone charger and I'm looking for a cheap Oz/NZ adapter to French 2 pin. . Cheers de Pete
9th Oct 2010, 9:39 pm | #90 |
One of these? http://www.jaycarelectronics.co.uk/p...l&form=KEYWORD
Alternatively I probably have a trailing socket around I could send over but the postage would probably be more than its worth! |
10th Oct 2010, 2:06 pm | #91 |
The pins on the NZ / Oz plugs look flimsy and easily bent but I don't know if they give much trouble in practice.
11th Oct 2010, 7:13 pm | #92 |
Thanks for that Arjoll, just what I had in mind. Thanks for the offer of a socket but, as you say, the postage would be steep. I should have bought a trailing socket or an adapter while in Oz. Mind you wifey didn't fancy spending a romantic anniversary trip half way round the world with me mooching round electrical shops . I did modify a UK shaver adapter and I could use that along with a UK to French adapter, but it's not very neat. The Aussie plugs I've got have quite sturdy pins. Maybe stronger than US plugs. Cheers de Pete
11th Oct 2010, 7:37 pm | #93 |
A point in favour of the Aus / NZ plug: the two-pin version is non-reversible, so (assuming that they were as careful about their wiring as us Brits) not much chance of an unpleasant surprise from an AC/DC set.
14th Oct 2010, 4:46 pm | #94 |
I read earlier in the thread about the Fitall plug, and, I have one...
Don't like it though, it's big, it's bulky, it has one fuse for all powers (5, 13 and 15), and it's very fiddly. It also doesn't fit modern style Shuttered BS546 sockets, cos the tips of the Earth pins are not rounded like on normal BS546 plugs.... Here's some pics of it (5Amp, 15Amp, 13Amp, under the cover and the stripped out innards): |
14th Oct 2010, 9:38 pm | #95 |
Rather OT (because I think it was a rather good design), but does anyone remember the make of 'quick-fit' 13A plug which had a 'core', removed by lifting and twisting the earth pin? The prepared cable was pushed into the core, and a plastic locking-ring tightened, then the core was returned to the shell.
I had one for several years, which I used for temporary connections in the manner of a Safeblock. |
15th Oct 2010, 10:38 am | #96 | ||
As I mentioned the only potential risk is anything wired for Chinese supply plugged in here - they use a similar plug with the same pin spacing and angles but mounted the other way up, and with phase and neutral swapped. It's all going to be newish and probably with a mains transformer or switch-mode supply so not really a drama. |
15th Oct 2010, 8:49 pm | #97 |
I've got a Fitall plug here somewhere as well as a quick fit one. Or I had them. The Fitall plug was originally advertised as fitting 5 different sockets. It would fit a 5amp and a 15amp 2 pin socket as well by squeezing the sides of the body. The fuse was a pig to remove too. Cheers de Pete
15th Oct 2010, 11:35 pm | #98 |
Ah, so that's what the purpose of the triangular slot was.
16th Oct 2010, 2:04 am | #99 | |
http://en.wikipedia.org/wiki/AC_power_plugs_and_sockets Martin |
16th Oct 2010, 3:38 am | #100 |
Aah, ok I must have been confusing the Chinese and Argentinian plugs!
One interesting thing - I picked up a cheap charger for Taniamaree's cellphone from a mall in Christchurch when we were up there during the week - it has uninsulated phase and neutral pins, making it technically illegal to sell! |
