Old 14th Feb 2018, 12:31 pm   #1
Tom Stone
Default PYE P45 stopped making sound.
Hi, wondered if any of you knowledgeable Ladys & Gents can offer me some advice.
I have had a PYE P45 displayed for a number of years and have recently got it down to give it a good clean. I remember when it went onto the shelf it was working but now when turned on everything works, lights come on but absolutely no sound whatsoever, not even a hissing or clicking. Have inspected the speaker and connections but can see anything out of place. I remember asking advice before on the forum concerning one of my other radios that had the same problem and was advised to change one of the valves, doing this resolved the problem. Would anyone know what valve on this set is connected with sound production?.
ECH42 EBF80 EL41 EZ40
Sorry, not very technical but can change a valve.
Thanks, Tom
Tom Stone is offline
Old 14th Feb 2018, 12:41 pm   #2
Station X
Station X's Avatar
Default Re: PYE P45 stopped making sound.
This set has a pick up socket.
Turn the waveband selector to GRAM, turn the volume right up and touch each connector of the pickup socket in turn with a metallic object such as a screwdriver.
A loud hum or buzz will indicate that the power supply and output valve are working correctly.
Graham. Forum Moderator
Station X is online now
Old 14th Feb 2018, 12:45 pm   #3
Radio Tech
Radio Tech's Avatar
Hi Tom
If you have got the circuit diagram, check through the circuit starting with the power supply, here you need to make sure that firstly the heaters of all valves are lit, then check to see if you have HT voltages off the cathode of the rectifier and on the anodes of each valve. The other thing is check the continuity of the output transformer and make sure the loudspeaker is not open circuit or disconnected from the set in some way. Hope this will give you a starting point in helping you solve the problem.
Best wishes
Ken
Radio Tech is offline
Old 14th Feb 2018, 12:48 pm   #4
G8HQP Dave
Is there any hum? This (and other Pyes) are known for magnetic coupling between the mains transformer and output transformer, giving a little speaker hum even before the valves have warmed up.
Unlike most other sets, you won't get much hiss from the audio stages as there is no audio voltage amplifier valve in this design. Any hiss has to come from the radio section. Because of this, you need all valves working to get any sound (apart from hum).
G8HQP Dave is offline
Old 14th Feb 2018, 1:09 pm   #5
Station X
Station X's Avatar
Originally Posted by Radio Tech View Post
Hi Tom
Best wishes
Ken
I think that if the OP is going to go down this route he'll need a bit more detail. Does he know which valve is the rectifier? Where does he connect his meter, assuming he has one? Which pins are the anodes of the valves? Are the expected voltages AC or DC and of what magnitude?
Old 14th Feb 2018, 7:40 pm   #6
Radio Tech
Radio Tech's Avatar
Hi Tom
Sorry, I should have realised about your experience, looking at the back of the set V4 nearest the mains transformer is the rectifier, underneath pin 1 starts from the pip on the valve and its pin 7 which is the cathode of that valve, the anode of the output valve V3 is pin 1 and V2 anode is pin 6 and V1 the first valve looking at the rear of the set its anodes are pin 2 and pin 3. The main smoothing capacitor is that one positioned right in the corner when the chassis is viewed from above, view this capacitor from underneath of the chassis and you should find a resistor soldered across the terminals of the capacitor, this may be open circuit, if the rectifier is doing its job you should find by measuring with a suitable meter (AVO) set on 300V range a DC voltage of 275V on the cathode.
And welcome to our forum
Best wishes
Ken
Old 15th Feb 2018, 6:55 pm   #7
Stylo N M
To answer one of the OP's questions, in layman's terms the EL41 would be the valve that is in direct connection with the sound output. Although a fault in any of the valves could result in no sound being present.
Paul.
Stylo N M is offline
Old 19th Feb 2018, 1:07 pm   #8
Tom Stone
Hi everyone, fantastic, what a fount of knowledge you all are. Yes, now have resolved the problem, in the end it was a simple fix as I just replaced the EL41 valve and hay presto, I have sound.
Thanks again to everyone for the info, absolutely fascinating although half of it I didn't understand but hopefully one day I will.
All the best, Tom
Old 19th Feb 2018, 3:05 pm   #9
Boater Sam
Good. Glad it now works but you need to consider replacing the EL41 grid 1 coupling capacitor, its leakage is possibly what killed the original valve. You risk another one or the transformer failing if it is leaky. Its often referred to as 'that capacitor'
Boater Sam is online now
Old 19th Feb 2018, 3:43 pm   #10
Cobaltblue
Cobaltblue's Avatar
That's interesting.
Valves rarely fail completely dead like that as a "step change" unless they loose their vacuum.
Had the top of the valve gone milky white?
This series of valves have a little pip to orientate the valve in the holder.
The holder has a wire clip that can knock the pip off.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 19th Feb 2018, 3:46 pm   #11
julie_m
There isn't one in a P45! It's a "short" superhet, with no gain stage between the detector and the audio output valve.
julie_m is offline
Old 19th Feb 2018, 3:53 pm   #12
Boater Sam
Sorry, never looked. Still its good advice for next time. I'm getting paranoid about newbies melting transformers. Set protection league member.
It is unusual for EL41s to just pack up.
' Its a valve, the sound valve, simple'
Old 19th Feb 2018, 4:23 pm   #13
G8HQP Dave
EL41 are quite likely to get a bit gassy, then go into thermal runaway and cook themselves.
