30th Sep 2015, 9:31 am | #1 |
RAF VT1 Valve
Has anyone got any technical info on the RAF VT1 valve from the 1920's/30's?
Apparently there are three varaints of the VT1, one is the GPO VT1 second is the RAF VT1 and third the US VT1 all different. They are all triodes but I'm looking for info on the RAF VT1 hoping to find a commercial equivalnet for a restoration project that I hope to get back on the air, well into a dummy load anyway. Thanks Brian |
30th Sep 2015, 11:08 am | #2 |
Re: RAF VT1 Valve
According to Jeremy at the Virtual Valve Museum, the VT1 commercial equivalent is the WE-203A. Data sheet here.
Some serious volts there! Cheers, Frank Last edited by frankmcvey; 30th Sep 2015 at 11:13 am. |
30th Sep 2015, 12:06 pm | #3 |
Re: RAF VT1 Valve
Thanks for that research Frank, seems a very handy tube, bit like an 807 on steroids (and less grids).
30th Sep 2015, 1:19 pm | #4 |
Re: RAF VT1 Valve
I can't find anything other than the US VT1 - the 1944 CV Register mentions a VT1A (CV1550) and VT1C (CV1551) (and no data of course) - I have the Keith Thrower and Tyne books at home, will check tonight.
Jeremy |
30th Sep 2015, 1:34 pm | #5 |
Re: RAF VT1 Valve
Hello,
Could it be the VT.1A http://www.r-type.org/exhib/aac0070.htm. If so I think it is a bright emitter. If so they, or an equivalent, do occasionally appear on ebay but expect to pay £80 to £120 for a good working one. Yours, Richard Last edited by Mr Moose; 30th Sep 2015 at 1:40 pm. |
30th Sep 2015, 1:42 pm | #6 |
Re: RAF VT1 Valve
Beaten to it by Mr Moose
As mentioned by Jeremy in post 4 there is a VT1A and that is described as an RAF transmitting valve originating in 1919 and an example can be seen here http://www.r-type.org/exhib/aaj0128.htm Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 30th Sep 2015 at 1:44 pm. Reason: Already posted by Richard |
30th Sep 2015, 6:22 pm | #7 |
Re: RAF VT1 Valve
Hi All
Thanks for the prompt replies I believe the Valve that Frank refers to the VT1/203 is the US version it appears to have short pins and a bayonet fitting on the Base. The Transmitter (a T21C) I'm rebuilding does not have a bayonet fitting. I think it's more likely to be the Ediswan on the R type web page thats got a more conventional base and it's British! So it's commercial equivalent maybe the T15. Any further Info much appreciated Brian |
30th Sep 2015, 6:56 pm | #8 |
Re: RAF VT1 Valve
None of my books added anything - the VT1 is only mentioned as the US version, VT1A is the earliest UK VT listed.
30th Sep 2015, 6:57 pm | #9 |
Re: RAF VT1 Valve
Drat - now I see the T21C reference - Google found http://www.rnmuseumradarandcommunica...YPE%20T21C.pdf
That lists it as VT.1A Jeremy |
