3rd Sep 2015, 5:18 pm | #1 |
DM70/DM71-LED Bargraph Display Modification?
I have recently taken delivery of an Eddystone 840C receiver which uses the above valve as a signal strength meter. I am no longer in the first flush of youth and my eyesight is none to good. Even though I have replaced the display, it is still difficult for me to make out any change.
I would be interested to hear from anyone who has successfully replaced a DM70/DM71 with an LED bargraph display. Thanks in anticipation - Alan |
3rd Sep 2015, 5:24 pm | #2 |
Re: DM70/DM71-LED Bargraph Display Modification?
3rd Sep 2015, 6:05 pm | #3 | |
When off-tune the whole 'question mark' display will be illuminated, and it takes quite a strong signal resulting in several AGC Volts negative to get the display to diminish to just a dot. I've attached a pic of a DM70 in a Pye radio that I have, and when relying just on the internal frame aerial and telescopic whip, the display doesn't change a great deal. If I connect an external aerial it will dim on strong broadcast station signals, but really, it's more of a gimmick than a useful indicator. I'm inclined to think that our ears are a better judge of peaks and nulls than a DM70! The DM70 is also used as a null indicator in those dinky Nombrex C/R bridges, and I've attached a pic of mine. The redeeming features on the DM70 are that they seem not to wear out, and they're not generally expensive - unlike for example, EM34s. Good luck with the LED mod if you decide to go down that route.
3rd Sep 2015, 6:24 pm | #4 |
Truth is, the AGC action of the Eddy 840 series never really made that much difference to the tuning-indicator display. I always thought of it as a gimmick rather than anything really useful.
And nowadays to resolve SSB you'll be operating with the switch set to "BFO" mode anyway - so the tuning-indicator will respond purely to the setting of the RF Gain control. |
4th Sep 2015, 1:21 am | #5 |
Thank you everyone for your replies. I have ordered a 10 segment bargraph display in green to start playing with. Somewhere I have a driver I.C which should make very compact unit which can easily be changed back to a DM70 if its next owner wants the set to remain as it was on the day it was born, not that I am planning to sell for yet a while.
Alan. Last edited by a_strong; 4th Sep 2015 at 1:25 am. Reason: Typo |
