30th Oct 2014, 4:40 pm | #1 |
Variable HT regulator circuit.
Can anyone point me in the direction of a simple solid-state VV circuit giving up to 100mA or so for adding to an existing 300V valve power supply?
Many thanks, Jim M0JBJ |
30th Oct 2014, 5:52 pm | #2 |
Re: Variable HT regulator circuit.
A simple MOSFET source follower will work well, keep in mind the SOA (safe operating area) of any FETs used, you (will?) need a few in parallel. I designed, and implemented, a constant current source at 450V and 10A maximum and ended up with 48 MOSFETs in parallel. OK they where cheap TO220 devices (50p each), in the end it worked out cheaper than a smaller number of bigger ones.
30th Oct 2014, 6:35 pm | #3 |
A Variac with asuitable isolating transformer feeding a choke filter? Not much current limiting though.
30th Oct 2014, 7:16 pm | #4 |
Thanks for those suggestions guys. The last Variac I used almost melted when a careless bystander managed to short it out!
30th Oct 2014, 7:38 pm | #5 |
This may be useful. Plenty of MOSFETS to choose from.
http://www.eleccircuit.com/the-varia...supply-0-300v/ |
30th Oct 2014, 8:51 pm | #6 |
Cheers,
I've got all those components! Jim |
31st Oct 2014, 12:23 am | #7 |
31st Oct 2014, 12:31 am | #8 |
Variable Voltage?
31st Oct 2014, 10:48 am | #9 |
Yes, that's right.
31st Oct 2014, 11:27 am | #10 |
Thank you. I suspected as such - wasn't sure. I've never seen that abbreviation for "variable voltage" before.
Al. |
31st Oct 2014, 1:46 pm | #11 |
To make the output smoother decouple the gate to the FET with a resistor from the pot and a capacitor to ground, 100k and 1u would do fine.
31st Oct 2014, 3:22 pm | #12 |
Cheers Merlin!
31st Oct 2014, 3:46 pm | #13 |
This seems to fit the bill - pity it's not in English though!
http://www.jogis-roehrenbude.de/Roeh...fs_Pruefer.htm |
31st Oct 2014, 4:06 pm | #14 |
Chris |
31st Oct 2014, 8:40 pm | #15 |
Cheers, that's very useful!
1st Nov 2014, 11:18 am | #16 |
When selecting the potentiometer, make sure it can withstand the voltage and power dissipation of your circuit. Most of the standard metal film resistors are only rated up to 350V.
Mosfets that are made with insulated packages like TO-220F are easier to fit to heatsinks. Keep the wiring to the gate of the Mosfet as short as possible. |
1st Nov 2014, 12:00 pm | #17 |
Thanks Silicon - I was wondering about the VR rating. I think I've some old wire wounds and I'll sort out one of those. Yes, it's a pity about the IRF840 not being insulated as I want to use the case as a heatsink, so it's useful to know about the TO-220Fs.
73 |
1st Nov 2014, 8:33 pm | #18 |
1st Nov 2014, 11:32 pm | #19 |
Thanks David; I have some of those I think.
Jim |
2nd Nov 2014, 10:34 pm | #20 | |
Thanks |
