4th Jul 2021, 5:52 am | #41 | |
Re: Multiprocessing SCMPII on MK14
4th Jul 2021, 10:30 am | #42 | ||
6th Jul 2021, 2:07 am | #43 |
Problem was due to the wrong crystal fitted. I had a 7.3728MHz fitted instead of 4.4316MHz. The setup time for address to NADS falling edge is dependent on the clock. Tc/2 -150 ns. At the higher frequency its just on the edge of the data setup time for the 74LS395 to the falling edge on NADS. Capacitance from a finger or scope probe is enough of a delay for it to work.
If I’m going to try and overclock the processors I should probably change to a positive edge triggered register or a transparent latch. |
7th Jul 2021, 12:09 am | #44 |
Just thinking about possible replacements of the 74ls395.
74ls163 is a possible. This is quite close to the pinout of the 74ls395 and might only need a simple mod to the wiring. The 74ls163 is a counter, but could be used as a latch if load input is held low and this would latch data on the rising edge at the end of NADS. There is still plenty of time in the rest of the bus cycle for any modern sram even with the scmp running at double the clock frequency. 74ls173 is also a good possibility, though the wiring mod is a bit more involved. The 74ls173 is also rising edge triggered but also has the advantage of a positive logic reset input, which could be driven by NENIN so the ortonview or mk14 vdu would force page 0. I also have the option of 74hct173 to reduce the load on the data bus. 74ls193 would give active low gated transparent latch with positive logic reset, though I don’t think I have any. I might have 74ls192 and although this is a bcd type I think that would only make a difference if the count function was used. |
