8th Feb 2021, 11:16 pm | #541 |
Re: Non-working Commodore PET 3016
I've just had a preliminary glance at it and I see that where the original code converted any character code below 32 or above 127 to a 'dot' you have broadened the scope so that it tries to print everything as ASCII.
The problem is that some characters aren't designed to be displayed, instead they may move the cursor to some other place on the screen or cause other odd effects so that is why the author of the original code filtered out those codes (and file viewers like HxD usually do the same, convert non-printable characters to a 'dot'. Don't get too hung up on trying to display the PROM content as ASCII. For certain PROMs like the BASIC 1 of 2 PROM which do contain a lot of text, the ASCII readout shows you instantly that everything is kind of working, but what you are really aiming for is to get the hex readout to be byte-for-byte identical to the hex readout of the original file. I had a quick look at some of the differences between my screenshot - taken from the original code loaded into HxD - and your screenshot of the code - I'm still not quite sure how you got the code out of your reader into a file to then load into HxD? Anyway - taking just one recurring byte from the original fragment that I posted, '1C', which occurs in a number of locations. Looking at the same locations in your snapshot they contain all different values, which is a shame - if they all contained the same wrong value we could have indulged in a bit of Bletchley style codebreaking to figure out how they were being jumbled up (two databits swpapped over, possibly) but it's nothing that obvious. |
8th Feb 2021, 11:24 pm | #542 | |
Hxd isn't very clever about recognising various types of file, by default, it assumes files are raw binary even if they are actually ASCII hex or Intel Hex. Just try this: Temporarily reduce the loop count from 2048 to just 256, so it only reads out the first part of the PROM. Compare the 256 bytes the reader has displayed with the first 256 bytes in the fragment I posted. Do the hex numbers match? |
8th Feb 2021, 11:33 pm | #543 |
Better look - they match now.
1c224a564c201e001824427e42424200 7c22223c22227c001c22404040221c00 78242222222478007e40407840407e00 7e404078404040001c22404e42221c00 4040427e424242001c08080808081c00 0e040404044438004244487048444200 4040404040407e0042665a5a42424200 4262524a464242001824424242241800 7c42427c40404000182442424a241a00 7c42427c484442003c42403c02423c00 3e080808080808004242424242423c00 42424224241818004242425a5a664200 00402418244242002222221c08080800 7e02041820407e003c20202020203c00 00402010080402003c04040404043c00 00081c2a08080808000010207f201000 |
8th Feb 2021, 11:41 pm | #544 |
1c 22 4a 56 4c 20 1e 00 18 24 42 7e 42 42 42 00
7c 22 22 3c 22 22 7c 00 1c 22 40 40 40 22 1c 00 78 24 22 22 22 24 78 00 7e 40 40 78 40 40 7e 00 7e 40 40 78 40 40 40 00 1c 22 40 4e 42 22 1c 00 40 42 42 7e 42 42 42 00 1c 08 08 08 08 08 1c 00 0e 04 04 04 04 44 38 00 42 44 48 70 48 44 42 00 40 40 40 40 40 40 7e 00 42 66 5a 5a 42 42 42 00 42 62 52 4a 46 42 42 00 18 24 42 42 42 24 18 00 7c 42 42 7c 40 40 40 00 18 24 42 42 4a 24 1a 00 7c 42 42 7c 48 44 42 00 3c 42 40 3c 02 42 3c 00 3e 08 08 08 08 08 08 00 42 42 42 42 42 42 3c 00 42 42 42 24 24 18 18 00 42 42 42 5a 5a 66 42 00 00 42 24 18 24 42 42 00 22 22 22 1c 08 08 08 00 7e 02 04 18 20 40 7e 00 3c 20 20 20 20 20 3c 00 00 40 20 10 08 04 02 00 3c 04 04 04 04 04 3c 00 00 08 1c 2a 08 08 08 08 00 00 10 20 7f 20 10 00 Here's a better text for comparison. Colin. |
8th Feb 2021, 11:53 pm | #545 |
Ah! That's better! The reader is actually working perfectly, it's just that HxD was trying to read your ASCII HEX file as a raw binary file.
You can make the reader sketch space the bytes out like that by making this small mod. (Maybe you already did?) Code:
// for (y = 0; y < 16; y++) { Serial.print(hex[ (d[y] & 0xF0) >> 4 ]); Serial.print(hex[ (d[y] & 0x0F) ]); Serial.print(" "); // <------ added space between columns } Any suggestions for a file format converter, ASCII hex to plain binary, anyone? |
8th Feb 2021, 11:58 pm | #546 | |
Could you make a checksum by adding the bytes together to make a checksum and displaying it in hex?. |
9th Feb 2021, 12:01 am | #547 | |
It shouldn't have. |
9th Feb 2021, 12:08 am | #548 |
Good, because we'll be letting you fly solo eventually.
That Mega will be one of the most powerful experimental / diagnostic tools you could ever have once you really get the hang of it. |
9th Feb 2021, 12:13 am | #549 |
For conversion of ASCII Hex to raw binary, it would be almost incredible if something like that did not already exist for Linux - I know you probably run a Windows PC but I expect all your Rasberry Pis run Linux.
Do you have Python installed on your PC? It's quite likely someone has written a Python utility to do it as well. ...Or maybe you can even write such a thing in REXX, which I confess I have never heard of. Anyway, I think you owe yourself a beer. I bet you wish you had hung on to the PROMs now. |
9th Feb 2021, 12:18 am | #550 | |
The page also suggests a windows program, although usual warnings about running .EXE files downloaded from the net apply! |
9th Feb 2021, 12:46 am | #551 |
Could alternatively modify the reader sketch to generate Intel Hex rather than plain ASCII hex, because HxD can 'Import' Intel Hex?
Then it would be possible to cut+paste the Intel Hex code generated by the reader into a plain text editor, save it as a file and import that file (as Intel Hex) into HxD. |
9th Feb 2021, 12:03 pm | #552 |
9th Feb 2021, 1:12 pm | #553 |
If I load the output from my program and the characters-2.901447-10.bin file, there are some small differences. For example at offset CO, my output is Hex 00 and in the bin files, it is 42. There are other examples - at 1C0, my output is 0E and the bin file is 3C.
Any ideas? *** EDIT *** interestingly all the differences are in the first character of each 16 character dump from the ROM - there are about 6 in total. Colin. |
9th Feb 2021, 1:15 pm | #554 | ||
9th Feb 2021, 2:02 pm | #555 |
Are the differences consistent? Do you get the same incorrect characters in the same places every time?
9th Feb 2021, 2:11 pm | #556 |
Also - are you sure those differences are present in the original reader readout, and not just being introduced by the online converter?
You should be able to scroll up and down the output from the reader in the Arduino serial monitor, to inspect all of its output. |
9th Feb 2021, 2:14 pm | #557 |
I'm wondering if, when you 'cut' the output from the reader, you are collecting a few extra (invisible) bits and pieces which are confusing the online converter. What do you paste the output into? It needs to be a plain text editor like Notepad, not a 'word processor' like Wordpad.
9th Feb 2021, 2:24 pm | #558 |
First difference - I have 00, .bin has 42 at C0
Second difference - I have 80, .bin has 04 at 240 Third difference - I have A0, .bin has 08 at 2C0 Fourth difference - I have 0F, .bin has FF at 3C0 Fifth difference - I have 18, .bin has 40 at 440 Sixth difference - I have 0E, .bin has 3C at 5C0 Seventh difference - I have 40, .bin has 42 at 640 Eighth difference - I have A0, .bin has 42 at 6C0 Ninth difference - I have 0F, .bin has FF at 7C0 |
9th Feb 2021, 2:24 pm | #559 | |
9th Feb 2021, 2:27 pm | #560 |
OK - give me time. I've looked at the original Arduino output on the screen and it's looking better.
Is there any way to output the Arduino output to a file instead of me having to cut and paste? |
