Old 21st May 2018, 10:10 pm   #1
dekor8tor
Default Hacker Gondolier GP42 and AL41 Amp
Hi all need a little help with my setup.
Both amps have a very loud humming especially when the volume is turned up and more so on the AL41 amp.
As far as I know both amps have Mullard mustards, is there anything else I need to change?
Thanks.
dekor8tor is offline
Old 21st May 2018, 11:10 pm   #2
GrimJosef
Default Re: Hacker Gondolier GP42 and AL41 Amp
I would start by working out what the fault is. That way you won't change anything pointlessly. Mullard mustards are normally extremely reliable.
Cheers,
GJ
http://www.ampregen.com
GrimJosef is offline
Old 21st May 2018, 11:34 pm   #3
RojDW48
RojDW48's Avatar
As a very general rule - volume dependent hum is a grounding issue - check the connections from the cartridge through to the amp(s).
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan)
RojDW48 is offline
Old 22nd May 2018, 9:44 am   #4
Edward Huggins
Is there still hum when the stereo adaptor is completely dissconnected and you are running the GP42 as a standalone player. There may be an earth loop.
Edward.
Edward Huggins is offline
Old 22nd May 2018, 9:43 pm   #5
dekor8tor
thanks all with your answers i will check to see if it is humming with the lead disconnected.
