Old 14th May 2018, 3:59 pm   #1
brightsparkey
Question Trouble with Grundig scale lamp holders
I'm appealing to anyone who has a Grundig set of 1960's vintage who understands how the scale lamp holders are meant to be arranged.
I have a 4070U and it came with two non-original lamp holders floating inside the case - a result of someone's less than thorough previous attentions and the parcel company.
A video from the US of a chap with a similar radio revealed the front view of the chassis that showed the lamp holders - two white plastic holders with a clip that slides onto a pair of lugs on the back plate. I managed to find a pair of similar lamp holders for sale and ordered them. They were red from a different set, but looked identical to those in the video otherwise.
They fit nicely on the lugs. There is a slot in the holder and the lug has a crease that slides into an opening in the slot, so it looks like the right approach. However, the lamps are presented so far forward that they touch the casework before the chassis is in place. I tried round lamps instead of the usual pear shaped lamps and even they are too far forward.
Does anyone know how these lamps are meant to work? Are there variations in shape of the lamp holders of this type?
I could make another bodge with some arrangement of different types of holder, but I'd quite like to use the original holders if possible.
Kevin.
ID:	162827   Click image for larger version
ID:	162828   Click image for larger version
ID:	162829   Click image for larger version
brightsparkey is offline   Reply With Quote
Old 14th May 2018, 4:49 pm   #2
erikossu
Default Re: Trouble with Grundig scale lamp holders
Well, the bulb has to reach over the edge of the back plate to illuminate the scale. I would use these little bit off the lug/set back so the edge of the holder-glass of bulb will be at the edge on the plate. Maybe these will fall of this way is hard to tell.
erikossu is offline   Reply With Quote
Old 14th May 2018, 4:55 pm   #3
brightsparkey
Yes if you slide them back they will fall off. Also they are in amongst the tuning cord so there isn't much room for manoeuver. In the pictures they have no lamp fitted, but are still close to the casework.
Old 14th May 2018, 10:55 pm   #4
vidjoman
Looks about right to me - I've done several Grundig radios and the lamp holders all have fitted like that. I haven't done the same model but don't think anything would have changed in other models.
vidjoman is offline   Reply With Quote
Old 17th May 2018, 1:56 pm   #5
brightsparkey
A mystery then !
I've ordered some push fit lamps (I'll soon have every 7V 0.1A lamp ever made...) to see if the holders are meant for them instead - there is no actual thread in the plastic.
The only other possibility is that the case work panel is not in the right place - the front looks fine, so I'd be surprised, but you never can tell.
Time to scratch head and have a pint.. and hope for divine inspiration..
Kevin.
Old 17th May 2018, 6:44 pm   #6
vidjoman
You may find that the metal contact bit has a sort of thread on it and it is that bit that will hold the lamp in place, assuming the plastic hasn’t expanded. They are definitely the screw threads on all the bulbs that I have seen.
