9th Apr 2021, 7:17 pm | #1481 |
Re: Non-working Commodore PET 3016
Wow! I'm very impressed.
Alan |
9th Apr 2021, 7:19 pm | #1482 |
Yeah I noticed that the day after I posted when I was checking something. I didn't think it was worth re-posting just for one character!
9th Apr 2021, 7:22 pm | #1483 |
I'm not sure I know what to say.
Colin. |
9th Apr 2021, 7:27 pm | #1484 |
Is the dark text on the right side a camera artifact or does it look like that IRL?
9th Apr 2021, 7:27 pm | #1485 | |
9th Apr 2021, 7:29 pm | #1486 |
Well now you're an expert you can find other PETs to fix I guess
9th Apr 2021, 7:31 pm | #1487 | |
There might be a few minor niggles still to sort, keyboard needs to be tested, IEEE interface may need sorting out, but this is a very good place to be in. |
9th Apr 2021, 7:33 pm | #1488 |
Just all round...
George |
9th Apr 2021, 7:38 pm | #1489 |
9th Apr 2021, 7:38 pm | #1490 |
I am almost sad this edge of your seat series is reaching its climax... Well done all around.
9th Apr 2021, 7:39 pm | #1491 | ||
9th Apr 2021, 7:42 pm | #1492 |
I'm going to have a couple of pints. And then I'll thank you all properly.
It repeatedly boots just fine. The keyboard needs attention - not many of the keys work but some do. There seem to be plenty of web pages giving advice on how to disassemble, clean and reassemble the keyboard so I don't intend to trouble anyone here with that unless I can't get anywhere. I have three datasettes to mess with and I have already bought a replacement set of belts so I will start with them. Are there simple scope tests I can do on the tape drive ports? Sirius - do you think we should have a grand closedown of this thread and for me to open a new one if I find other faults, or is the IEEE worth testing first in this thread? Colin. |
9th Apr 2021, 7:45 pm | #1493 |
I think it isn't over until it is over, so let's just carry on to wherever this ultimately ends up. Just keep us updated with how you are progressing, it will be nice to see it running something eventually.
9th Apr 2021, 7:51 pm | #1494 |
Congratulations, so glad you had the patience and determination not to replace all the ram chips.
I think the IEEE, keyboard and datasette refurbs would be good to have separate threads, so its easier for anyone else to find later, but I think you should keep this thread open until the PET is in complete working order again and post final pictures of it doing something. |
9th Apr 2021, 7:53 pm | #1495 |
Oh, by the way, Daver2's test code will probably work as intended now if you fit that in UD8 position. I think it has a low level keyboard test, among other things.
9th Apr 2021, 8:02 pm | #1496 |
Well when I'd said that changing just UE10 for now would hopefully make a 'significant difference', I wasn't quite expecting it to quite get that far!
- So a very welcome result, and congratulations (You even got a Selfie with it in the first screen's reflection!) And most surprising, that with so many TTL IC failures, that the usually more fragile RAM IC's have all survived! - Hopefully those intermittent screen errors you'd had will also have gone away. Plus, presumably that daver2 PETTESTER EPROM will now get past the screen test and do it's test on the main RAM. So it might be worth trying that one as well, whilst it's working - just to check that it does run OK, in case it might be useful in future. There's been a few recent datasette on PET's fixed, so should hopefully be able to get those you have working - although I'd expect at least one works electrically, at least. |
9th Apr 2021, 8:20 pm | #1497 |
Just want to add my congratulations! I've been following this thread, and always looking for the next instalment! I kept out of the way as I know absolutely nothing about these things, well done for persevering with it, I'd have probably given up about 60 pages back!
Regards, Lloyd |
9th Apr 2021, 9:16 pm | #1498 |
On the survival of the RAM chips I suspect the buffers did their job and protected them it is likely that timing errors caused several buffers to drive at the same time wiping each other out... Just a theory...
9th Apr 2021, 9:32 pm | #1499 |
Wow! That's fantastic!
Code:
10PRINT"IT WORKS!" 20GOTO10
10th Apr 2021, 12:08 am | #1500 |
Colin also changed some of the chips controlling the buffers, so its possible they went first and left the buffers fighting against each other. It might have been a lucky break that the control logic for CAS and RAS also failed which kept the ram outputs out of the fight.
