8th Jun 2018, 3:58 pm | #1 |
Bush SRP 64 deck removal
Hello All
I have recently recovered my wife's 1970 Bush SRP64 record player from the attic and hope to get it working for her birthday. I have a few questions and i am hoping someone can help. 1) Where can i buy parts for this model (missing two control knobs) 2) How do i remove the deck from the cabinet 3) The automated return arm doesn't work at all and i have been unable to remove the cogged wheel using medium force (don't want to break it) i have taken the spring clip off ?. looking forward to hearing from other members with a lot more knowledge than I |
8th Jun 2018, 4:59 pm | #2 |
Re: Bush SRP 64 deck removal
1: You can buy some parts such but certainly not the original knobs. But you can buy near equivalents via an online search. Many Guitar amplifier specialists sell similar.
2: Unscrew the (6?) chrome headed screws around the black motorboard and lift the whole assembly out. Don't strain the leads. It's best to screw up the deck's transit screw first. 3: This is late (1973) model BSR deck and there are Stickys above that may help with the automatic mechansim. Also, search for a service sheet - the label on the underside of your deck should say something like Model C129.
Edward. |
8th Jun 2018, 5:36 pm | #3 |
This may be far from straightforward as you don't seem to be experienced at electronics/restoration and the record player will probaly need quite a bit of work/ diagnosis by now! Take a look at the excellent "Reviving Your Record Player "stickie" in this section. You can also do a search for information on tackling your player from previous threads here. It will give you a good idea of what may be involved.
How soon is the Birthday by the way? Dave W |
8th Jun 2018, 5:43 pm | #4 |
Re: 2) Instructions can be found in the link in Post#7 in this thread:
https://www.vintage-radio.net/forum/...d.php?p=847688 Lawrence. |
8th Jun 2018, 5:51 pm | #5 |
Much appreciated for the replies, got the return/loading arm working now.
Thanks. |
