21st May 2018, 9:54 pm | #21 |
Re: Philips 50IC36 No FM
If the local osc is working you could still get beats but you will be able to tell with the frequency in use.
If you have a SG you could also feed a 10.7Mhz signal into the IF strip to check if that is working, it’s another test. I will feel bad if after this it is the IC but I always think testing is better than just guessing.
Frank |
23rd May 2018, 2:01 pm | #22 |
Hello all,
Thanks to all for your input and help. The problem is solved. It was to do with the supply for the Varicap tuning. The circuit board is a small board separate too the main PCB. I lifted the board so that I could get access to measure the voltages on the voltage converter circuit, TC428. As I lifted the board the FM came to life, just for a moment. As I turned the board over a wire just fell away. This was the wire that goes from the adjustment pot R686 to feed the +4V to the tuning circuitry. it could never have been making a good connection and must have been a very dry connection for a long time. It was soldered back and all FM channels were working. Once again, thanks to all. Regards Dave. P.S. Frank, no need to feel bad, it wasn't. |
23rd May 2018, 2:05 pm | #23 |
Excellent news, well done.
Frank |
23rd May 2018, 2:51 pm | #24 |
If it’s not all boxed up it would be interesting and educational to see what your scope shows on the tests you did earlier.
Frank |
