Old 10th May 2018, 4:39 pm   #1
G4YVM David
G4YVM David's Avatar
Default WS19. No audio.
I've got my friend's 19 set going to the point that the heaters glow etc. I'm sure it does work fine, but I can't get audio from it. I am connecting a speaker to the pin 4 and chassis but get nothing. Now, is this because the modern low impedance speaker won't do the job or because I might have an issue? Pin 4 on plug 2A is the right pin, the intercom relay works which makes me think the set is fundamentally fine, so what am I missing?
G4YVM David is offline
Old 10th May 2018, 5:32 pm   #2
radiotechnician
Default Re: WS19. No audio.
Make sure the receiver is receiving and look at the attached schematic and description.
I would go to the cap of the 6B8 G.
What you would be missing is a cup of tea instead of digging into 60+ years of crystalized crud on the wiring under the chassis.
Name:	WS 19 A  RECEIVER OUTPUT SCHEMATIC.jpg
ID:	162558   Click image for larger version
Name:	WS 19 A RECEIVER OUTPUT STAGE DESCR.jpg
Steve Dow
VE7ASO
radiotechnician is offline
Old 10th May 2018, 5:33 pm   #3
Radio Wrangler
Radio Wrangler's Avatar
I thought the 19 set only drove headphones unless someone added an audio power amp stage.
How original is it?
Radio Wrangler is offline
Old 10th May 2018, 7:09 pm   #4
HamishBoxer
HamishBoxer's Avatar
I think mine is headphones only.
HamishBoxer is offline
Old 10th May 2018, 10:51 pm   #5
mike g3zii
Hello, You should hear something on the headphone output with a speaker.
On mine unmodified, it's there but not super loud. I matched mine to a 3 ohm speaker by using the rx output transformer of a Pye vanguard . the winding driven by the transistor output steps down the impedance and ups the power output.
but you probably have not got one of those handy.
I would do some fault finding around the 6B8 stage as already suggested.
The output transformer could be suspect. best of luck with it.
mike g3zii is offline
Old 10th May 2018, 11:19 pm   #6
Argus25
No Longer a Member
David, if the speaker is not matched you should still hear the audio, it will just be quiet.
Actually, I'm pretty sure that this set would have had similar audio power output power and headphone impedance to the ZC1 receiver. If you scroll to page 77 of this article, there is a method to make a small extension speaker box and impedance match it. Even though the ZC1 had only an RF pentode as the audio output valve and was made to drive headphones, a correctly matched speaker gave more than enough volume in a standard room. So I think this method would work for your 19 set too, after you have fixed the current fault.
http://worldphaco.com/uploads/ZC1_MK...R_SUPPLIES.pdf
Hugo
Argus25 is offline
Old 11th May 2018, 1:27 am   #7
radiotechnician
Here is a picture of the earphone cone for WS19 headgear
that was used in the tanks. The DC resistance is about 64 ohms.
I believe the output impedances for the B , A , and intercom
sets was 500 ohms. The level would have sufficient to travel
through field wiring to reach a remote operating R/T post.
Both the microphone and earphone used the same cone type
speaker assembly (as far as Canadian apparatus that I had
worked with). The remote station microphones and earphones
were carbon, and non-cone telephone type.
There were groups of WS19 aficionados who owned the sets
and held ham radio events with them.
Name:	Headgear for WS19 photo of earphone diaphram DCR 64  OHMS.jpg
Steve Dow
VE7ASO
Old 11th May 2018, 2:15 am   #8
Argus25
No Longer a Member
sets was 500 ohms.
That is close to the ZC1 earphones that I think were 100 Ohms DC resistance and the impedance not a lot different.
With a pair of small 32 ohm speakers in series then, the 19 set would probably have plenty of audio output and not require a matching transformer.
Argus25 is offline
Old 11th May 2018, 6:18 am   #9
G4YVM David
Thanks all. I tried adding a simple resistor to the speaker line then I removed it and usd an audio amp I built instead. Now I get audio but it's just noise and hash. No signal gets through it all, even when 'injected'from a nearby transmitter.
Methinks she is dead somewhere. The audio valve is heating ok.
D
Old 11th May 2018, 7:23 am   #10
vosperd
vosperd's Avatar
As mentioned the ws19 will drive a 3 Ohm speaker but it will be low volume and will dampen the mod on transmit. I use a 600 Ohm speaker as used on some communications receivers and it works fine. Do you have any indication on the AVC position on the meter switch with a strong signal?
I have had problems with the toggle switches failing or sometimes just not switching on if not used for some time.
Don, m5aky
vosperd is offline
Old 11th May 2018, 8:15 am   #11
Keith
Keith's Avatar
The output transformers (T2A) have a tendency to go o/c primary (probably due to the dreaded "green spot" corrosion). As Don has said, with an input signal, you should see a (downward) deflection on the meter in the AVC position if the RF side is working. Another source of possible problems is dirty relay contacts. All the circuit information, etc, is available for download on the VMARS manuals page.
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
Old 11th May 2018, 9:06 am   #12
vosperd
vosperd's Avatar
If it turns out to be the output transformer, Sowter were making replacements. Last time I checked the price worked out at about £60.00 including VAT and carriage.
Don
vosperd is offline
Old 11th May 2018, 6:43 pm   #13
Orakle42
Hi David
As already suggested T2 has a tendency to fail, also, a good dose of switch cleaner can work wonders round the relays and wafer switches. [don't forget the meter switch it can produce false readings].
Orakle42
Orakle42 is offline
Old 14th May 2018, 10:14 pm   #14
G4YVM David
Thanks all, I'll either work on this or not...trouble is, the owner has now bought aT1154/R1155 so this 19 set is effectively surplus. We shall see.
Thanks though...I'd like to fix the audio.
