| Success Stories If you have successfully repaired or restored a piece of equipment, why not write up what you did and post details here. Particularly if it was interesting, unusual or challenging. PLEASE DO NOT POST REQUESTS FOR HELP HERE! |
#1 |
I bought a Microwave modules 144MHz power amplifier, 144/30. This will give 30W out for 1W in. Fairly old but interesting. Anyway powered up and went to transmit and....nothing on the output. The built in preamp worked though.
I found a circuit on the net and concluded that one of the changeover relays was not pulling in. I opened up the case and took the top off of the relays so I could see what was happening. Sure enough the changeover relay from RX to TX was not doing anything. Close inspection showed that there was a lot of green stuff near one end and I could just make out a break in the wire. So I unsoldered the relay from the PCB and removed all the contacts to gain access to the coil. Close look with a magnifying lens showed that there was a break where the green stuff was. I carefully cleaned the area and lifted both ends of the winding clear. The insulating lacquer was scraped and both ends tinned. Then a short heat with the iron and the joint was made. There was now continuity on the coil. I rebuilt the relay and soldered it back into the board. With new heat-sink compound on the PA transistor I fired it up. With 1W in I now had 25W out into a dummy load. I could have bought a new relay but where's the fun in that. Malcolm G8KGH |
#2 |
I think you could term that a lucky break!
Great that these M Modules are fixable. Well done to find the problem. Mike. |
#3 |
Nicely done!
