5th Jul 2010, 12:48 pm | #1 |
5 Band resistor Colour Code
Can someone refresh my memory as to this. I know that the 1st colour is 1st figure, 2nd C. is 2nd Fig., 3rd is multiplier, all using the conventional colour codes with which we are all familiar. My question concerns the last two bands, one of which is tolerance, what is the other, and which is which?
5th Jul 2010, 1:15 pm | #2 |
Re: 5 Band resistor Colour Code
ISTR it is Temerature co-efficient. But as to which way round they are, haven't a clue.
Anything with more than four bands I check with a DVM................. Then there are those ones with a total of six (FOUR bands for the value), which I have never got to grips with, never knowing which end to start!
5th Jul 2010, 1:20 pm | #3 |
See attached.
Google resistor colour code and you'll get lots of pretty ones Alan |
5th Jul 2010, 1:23 pm | #4 |
It's for tight tolerance with a temp coefficient.
See this :- http://en.wikipedia.org/wiki/Resistor_color_code |
5th Jul 2010, 2:06 pm | #5 |
However a lot of modern resistors are marked: Band 1 first figure, Band 2 second figure, band 3 THIRD FIGURE!, band 4 number of zeros, band 5 tolerance (usually 1%, occasionally 2% for these 3-figure codes). And that makes 5 bands! So 1k 1% is marked, brown, black, black, black, brown, brown.
5th Jul 2010, 2:13 pm | #6 | |
5th Jul 2010, 5:05 pm | #7 |
But not so good when you get a batch of boards with 120R 1% fitted instead of 10K 1%. BTDT
5th Jul 2010, 7:17 pm | #8 |
My question arose due to what I thought was an o/c 47K resistor in a Marantz amplifier-this resistor being marked Yellow, Mauve, Brown, Red(or Orange), & Silver.
On checking the circuit diagram it turned out that this resistor is 47 OHMS(as per the first 3 colours) The Silver band = +/- 10% tolerance, but I'm still not sure what the red(?Orange?) band indicates. |
5th Jul 2010, 7:20 pm | #9 |
Yellow 4
Violet 7 Brown 1 Gold x0.1 Silver 10% Hence 47.1R, 10% Very odd having 10% tolerance on a resistor specified to 3 significant digits. |
5th Jul 2010, 8:03 pm | #10 |
High stability resistors used to have a pink band as the last one.
John |
5th Jul 2010, 10:22 pm | #11 |
Mm that resistor colour code compared to its value doesnt make sense whichever way you read it.
Modern equipment never uses 10% resistors, minimum is 5 and usually 2%
Kevin |
6th Jul 2010, 7:41 pm | #12 |
You may find this free programme useful. I've used it as a teaching aid.
http://myfreewares.weebly.com/resist...de-solver.html |
6th Jul 2010, 8:58 pm | #13 | |
Thanks for that one.
