30th Apr 2010, 2:47 pm | #21 |
Re: High voltage SMPSU
Yep, I have had to fit DC-DC converters as isolators to Lascar panel meters and switching noise was a pain. However the meters were tamed from dancing about by applying chokes and decouplers. The latter had to be kept low in value else they caused failure of the isolators.
30th Apr 2010, 6:37 pm | #22 |
I'll give it a try and see how it works. I'm still gathering the parts for the Sussex so it may be a long time before I actually begin to build it.
Timo |
6th May 2010, 7:59 pm | #23 |
Was looking for something else ,but if nobody minds ,can I make a suggestion . The circuit idea is from some old telecomms equipment ( getting 28 v on board from standard 24v input) ,and would work from a 12v source .( I did get 240 out -naughtly using a standard transformer - I know losses were horrendous ,but it fired up my zenon strobe for car timing ) .
Used a LM494 IC( smpu chip) .To get losses down ,would need a toroid transformer capable of handling KHZ .Drive output from chip is about 200mA in push pull, but a couple of meaty transformers would soon cure that if more needed .Circuit design is similar to that on Texas pages ,and we found on bench that it gave out very little hash .We did regulate the chip input to 12v with a zener ,which sometimes gave funnies on the output waveforms . Regulation is by feedback ( derived from a regulated portion of the output voltage ) .It is possible also to get overcurrent protection too . Problem might be sourcing this chip -though think that RS still do them . |
7th May 2010, 12:29 am | #24 |
Drive output from chip is about 200mA in push pull, but a couple of meaty transformers-from my post -should be "meaty transistors" - but the edit function on my last post has gone walkues .
7th May 2010, 7:37 pm | #25 |
That chip should be TL494 ,by Motorola -just found part of a data sheet .
7th May 2010, 8:01 pm | #26 | |
Timo |
7th May 2010, 11:38 pm | #27 |
Sorry -got MFR wrong ,was TI - http://focus.ti.com/lit/ds/symlink/tl494.pdf
REFERS -IF ANY USE .Used this circuit ( with only voltage side ) on a convertor -works well ( but with massive inneficiencies, only used a 50 hz tx- to step up car 12v to 240 for zenon strobe ) - however the TI data sheet gives winding data for a 28v output -etc - if anyone can give /get equivalent transformer core data -Ferroxcube seems to have vanished .From my research it seems only places like RS stock this chip ( and I'm sore ,as not so long ago Ihad a cleanout of my old stuff -taking up too much room - oin that batch was about 30/40 TL494 . Good luck . Last edited by Dave Moll; 12th May 2010 at 8:28 pm. Reason: unnecessary quote of preceding post removed |
11th May 2010, 11:01 pm | #28 | |
So -if it's any use - and ( no promises ) - I might be able to convert the PCB into a drawing ,if needed -so ask ,and I'll try . |
12th May 2010, 8:40 am | #29 | |
Timo |
