Old 27th Aug 2019, 11:09 pm   #1
mahmoodi
Default Sony SL-T9 no colour.
Hi All
I am new here
My device is working Sony SL-T9 but there are no colors only black and white
Thank you
mahmoodi is offline
Old 29th Aug 2019, 6:29 pm   #2
dj_fivos_sak
Default Re: Sony SL-T9 no colour.
Did you try playing tapes recorded in PAL as well as SECAM? Since it's a multi system machine, the Chroma circuit can be a bit complicated.
Fivos
dj_fivos_sak is offline
Old 30th Aug 2019, 8:50 pm   #3
mahmoodi
Hi.
No I do not have any SECAM Tape just PAL and tried many Tapes also same, before storing it many years back it was working fine.
mahmoodi is offline
Old 8th Sep 2019, 5:52 am   #4
dj_fivos_sak
Can you take high-res pictures of the AV-2 and YC-16 boards? I haven't worked on this model before but I'm assuming there will be an AFC adjustment somewhere...
Fivos
Old 26th Sep 2019, 9:26 am   #5
mahmoodi
Hi
I tried the AFC but no luck, its on AV-2 Board , any other choice ?
mahmoodi is offline
Old 27th Sep 2019, 11:52 am   #6
dj_fivos_sak
If you have a capacitance and an ESR meter, check all the capacitors in the luminance and chroma boards and verify that the power supply voltages are correct. Also, try to find a SECAM tape or record a new one, if possible and see if the colour is OK in SECAM. You can download the schematics here:
https://drive.google.com/file/d/1NHk...ew?usp=sharing
Regards
Fivos
Old 27th Sep 2019, 11:02 pm   #7
mahmoodi
Thank you Very much , Yes I have ESR Meter . I will look at that ..
mahmoodi is offline
