26th Jul 2018, 3:04 pm | #1 |
Speaker crossover capacitor
Ferranti A1016 - tweeter not outputting much at all. I found the crossover 'filter' cap. between main unit and tweeter is cracked and measures very high. It's a large Hunts black tar type marked A103 'Metallised' 2.0 uF 150V. It measures as nearer 7uF ! Tweeter tested in isolation it seems ok, so want to replace this cap. but can't find any non electrolytics suitable online. As it's mounted in a clamp I might have to make up a container if a modern one is smaller - but first need to find any suitable one.
Thanks - Paul |
26th Jul 2018, 3:13 pm | #2 |
Re: Speaker crossover capacitor
Use a couple of 4.7uf electrolytics back to back, no point spending lots on a non electrolytic for the A1016.
Frank |
26th Jul 2018, 3:18 pm | #3 |
Motor run capacitor?https://www.ebay.co.uk/itm/CBB61-mot...bxnftOkISe9VDA.https://www.ebay.co.uk/itm/Metalised...21KOHlIBvWaT7w
John Last edited by jonnybear; 26th Jul 2018 at 3:24 pm. |
26th Jul 2018, 3:41 pm | #4 |
2.2uF 630v polyester cap on ebay is £3.35 for 2.
These tweeters were never designed to give out much sound. Mike |
26th Jul 2018, 6:13 pm | #5 |
26th Jul 2018, 7:48 pm | #6 |
Back to back electrolytics should behave much like a single non-polarised capacitor. Sonic artefacts are likely to be minimal as far as human hearing is concerned. Also, it doesn't matter which 'poles' are connected together.
Alan |
26th Jul 2018, 8:01 pm | #7 |
The polyester caps from posts 3 and 4 are a decent price, I didn’t want you spending lots of money on “special Audio” capacitors. If you have the electrolytic ones I would use them, if you have to order them you may as well order the ones in either post 3or 4.
Frank |
26th Jul 2018, 11:01 pm | #8 |
When electrolytic capacitors are wired back-to-back, if the dielectric layer begins to break down in the capacitor which is "in reverse", then the capacitor which is "the right way round" limits the fault current. The dielectric layer will begin to re-form after the next reversal of polarity.
It sounds crude, but it works!
27th Jul 2018, 12:49 am | #9 |
You can get ordinary yellow ones at 2.2uf for a couple of quid.
http://uk.farnell.com/vishay/mkt1813...ial/dp/1166846 |
27th Jul 2018, 8:44 am | #10 |
Cricklewood do these at £1-50 plus postage.
https://www.cricklewoodelectronics.c...vers-etc..html 3rd item down. Purpose made part. Tony |
27th Jul 2018, 9:13 am | #11 |
Hi Paul,
Lots of choices, use which ever is the easiest for you, they will all work.
Frank |
