Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 11th Jul 2015, 12:39 pm   #1
terrybull
Default Pictures upside down
Not unique to this site but if I use my ipad to post a jpeg on here it always seems to get inverted. I have even posted an inverted image in the expectation it will be the right way but alass no. Do others have this issue.
terrybull is offline
Old 11th Jul 2015, 7:55 pm   #2
Paul Stenning
Administrator
Paul Stenning's Avatar
Default Re: Pictures upside down
The software here doesn't recognise the rotation data embedded in JPEG files from mobile device cameras, so if they are uploaded directly this can happen. If you edit and save first (perhaps using the Photoshop app if it's available for iOS) then they should appear correctly here.
Paul Stenning
Paul Stenning is online now
Old 12th Jul 2015, 11:54 am   #3
Sean Williams
Sean Williams's Avatar
It is common on all Apple products. I just save mine to my PC and rotate - I find using the forum from a phone difficult anyway.
Sean Williams is offline
Old 12th Jul 2015, 1:03 pm   #4
I use the 'save for web' function in Photoshop, all you get out is a .JPG no fancy formatting etc.. What you see is what you get.
Old 12th Jul 2015, 7:50 pm   #5
peter_scott
peter_scott's Avatar
After rotating the image save it with a new name. Some applications love to ignore the fact that you have changed and saved an image but they don't ignore a "new" file.
Peter
peter_scott is offline
