28th Jun 2020, 9:56 pm | #1 |
ED15TV1 high voltage diode spec?
I recently received some ED15TV1 diodes along with some BY182's from a kind forum member. I wanted the BY182's for EHT rectification purposes for rebuilding triplers in 625 line TV's. Other people have used these with success, but the question is: would the ED15TV1's also be suitable for this purpose? I guess the crucial parameter is recovery speed, given that they would seem to be rated at 15KV. There seems to be very little info on the 'net, the best I managed to find was a data sheet in Chinese! So, does anyone have any data on these devices? Especially the maximum frequency they will work up to? Many thanks Nick Last edited by 1100 man; 28th Jun 2020 at 9:58 pm. Reason: text altered |
28th Jun 2020, 11:32 pm | #2 |
Re: ED15TV1 high voltage diode spec?
It's easy to construct a shaky cascade of assumptions- but I would guess that a 15kV rating and the inclusion of "TV" in the part code meant that they were effective at least to the frequency associated with the flyback pulse component of 525/625 line output stages on the grounds that mains EHT systems were a long time in the past when they were made.
Colin |
30th Jun 2020, 8:55 pm | #3 |
Hi Colin,
Thanks for the reply. I've been trawling the 'net again, but can only come up with the one, rather unclear data sheet. It shows t rr (ns) as 500, but also shows a diode symbol with (micro second) in brackets. t rr would seem to be recovery time, but as to whether it's 500 nano seconds or 500 micro seconds, I'm not sure. So I then tried to find the t rr for the BY182, but no luck with that either! At least I could have compared the two! Maybe I'll just have to do some experiments with them at some point and see if they work in a tripler configuration. Cheers Nick |
