23rd Jun 2020, 7:18 pm | #1 |
Enarde 7855 nrd identification
Any Ideas on this item found in box of crystals.
John |
23rd Jun 2020, 10:03 pm | #2 |
Re: Enarde 7855 nrd identification
Is that mercury inside it? If so, some form of high power position-sensitive switch would be my guess.
dave
Dave Teague |
24th Jun 2020, 8:50 am | #3 |
Hi Dave
I can't see any mercury in the unit just a metal sleeve connected to one contact and a ceramic insulated inner wire connected to the other end, each contact is different size so there is obviously a correct orientation. There is a marking in pencil of 600v so suppose it could be a spark gap or something. John |
24th Jun 2020, 2:58 pm | #4 |
If you can measure (or estimate!) the 'gap' length that may or may not confirm 600v (but that seems quite a low voltage for a spark....)
Dave Teague |
24th Jun 2020, 3:45 pm | #5 |
Perhaps a gas-filled stabiliser tube? 600V does not sound unreasonable for that. Or a spark gap operating at low gas pressure (which will flash over at a lower voltage than the equivalent gap in air at atmospheric pressure I think)
24th Jun 2020, 3:53 pm | #6 |
T/R spark gap tube?
Lawrence. |
24th Jun 2020, 5:10 pm | #7 |
An Enarde logo comes up with Nucleonic And Radiological Developments Limited in Google books:
https://books.google.co.uk/books?id=...6AEwAXoECAMQAg Lawrence. |
24th Jun 2020, 5:42 pm | #8 |
They also did corona discharge tubes for voltage stabilization:
https://worldradiohistory.com/hd2/ID...evelopments%22 Lawrence. |
24th Jun 2020, 5:43 pm | #9 |
Early GDT. Even the little ceramic ones of today have radioactive gas inside - IIRC.
24th Jun 2020, 8:26 pm | #10 |
Geiger tube ?
Ed |
24th Jun 2020, 9:25 pm | #11 |
It looks very much like a corona discharge regulator to me.
Possibly similar to this one, but with a cap connector instead of pins: http://www.r-type.org/exhib/aaa0524.htm |
